[mapguide-users] Please try your operation later as theresource
was busy
George McLean
gmclean at gorge.net
Sun Jul 20 14:05:47 EDT 2008
I am also seeing this problem Apache-PHP running on XP SP2 with MG 2.0.
I am confident I am closing the feature reader before calling the
update. At this point this is the only thing keeping me from putting MG
2.0 into production. I saw a comment that suggested setting the content
expiration to immediate. The suggestion was from an IIS user. So far I
have not figured out how to set this in Apache in Windows.
Any suggestions?
Thanks
George McLean
Mark Pendergraft wrote:
> I have not found a solution to the issue, it's a bug in 2.0 and there is
> already a trac ticket for it(http://trac.osgeo.org/mapguide/ticket/524)
> The solution I have come up with, is to roll back my map to 1.2.
> Sorry for the bad news
> -Mark Pendergraft.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of dirk-64
> Sent: Thursday, June 26, 2008 11:57 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Please try your operation later as
> theresource was busy
> i'm using MGOS2.0 and got the same error when trying to update the
> feature
> source i just had read from, by the feature service's UpdateFeature
> method.
> I closed the feature reader and call the delete method of
> MgFeatureReader
> before. Neither the Close nor the delete makes any difference, the error
> stays the same:
> MgFeatureReader locReader = featureService.SelectFeatures(featureId ....
> locReader.ReadNext()
> locReader.Close();
> locReader.delete();
> featureService.UpdateFeatures(featureId, cmdCollection, false);
> did you found any solution to your issue - probably the same like i'm
> looking for,
> dirk.
> A H wrote:
>> i'm using MGOS1.2 and got the same error while trying to query a
> recently
>> updated layer
>> MgFeatureQueryOptions locQuery =
> new MgFeatureQueryOptions();
>> locQuery.SetFilter("ID like
> locLayer.SelectFeatures(locQuery);
>> MgSelection selection = new
> MgSelection(map);
>> selection.AddFeatures(locLayer,
> locReader, 0);
>> selectionXml =
> selection.ToXml();
>> Please try your operation later as the resource was busy:
> Session:98c4f84e-ffff-ffff-8000-00508bbe3169_en_0A0223600AFC0AFB0AFA//Lo
> cation.FeatureSource
>> Exception occurred in method
>> MgServerResourceService.RemoveCachedFdoConnection at line 2234 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src
> \services\resource\ServerResourceService.cpp
>> Bruce Dechant wrote:
>>> Mark,
>>> The access is similar to a database, except is dependent on what the
>>> underlying provider supports. In the SDF case I believe this is
> multiple
>>> reads and single write is supported.
>>> Thanks,
>>> Bruce
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
>>> Pendergraft
>>> Sent: Friday, May 16, 2008 1:03 PM
>>> Subject: RE: [mapguide-users] Please try your operation later as the
>>> resource was busy
>>> I'm a little confused here.
>>> You make it sound as if only one person can update the library
> resource
>>> (in
>>> this case a .sdf file) at a time. I thought that multiple people
> could
>>> interact with the file making changes at the same time more like a
>>> database.
>>> I get this error about every other time i try to add a feature to my
>>> feature
>>> source. There is a lot of code that could be suspect, i will try to
>>> isolate
>>> the error this weekend and if it's not my code i will submit a trac
>>> ticket.
>>>> Mark,
>>>> The error you see below is typically a result of the resource still
>>>> being
>>>> used by someone else. However, if a feature reader is not closed and
> you
>>>> try to do something with the same resource (update) it can report
> that
>>>> it
>>>> is in use still and therefore busy.
>>>> Since you are closing your feature reader I suspect the problem is
> most
>>>> likely a defect if you are the only one that is using it.
>>>> What provider is this happening with? Is this easily reproduced?
>>>> If you could create a track ticket for this and include as much
>>>> information as possible for someone to investigate the issue that
> would
>>>> be
>>>> great.
>>>> Thanks,
>>>> Bruce
>>>> Pendergraft
>>>> Sent: Friday, May 16, 2008 11:44 AM
>>>> Subject: Re: [mapguide-users] Please try your operation later as the
>>>> resource was busy
>>>> I am getting this message too. I am closing my feature reader and
>>>> disposing
>>>> of it.
>>>> The problem happens when the user adds features to one of the
> feature
>>>> sources named "Jobs". We use our map primarily to track where we
> have
>>>> worked, and users need to be able to add jobs to the map. Sometimes
> it
>>>> works, other times it harrasses me about the resource being busy. I
>>>> would
>>>> have to use the library resource because the changes need to show up
> in
>>>> everyones map.
>>>> Am i missing something here? is there a way to possibly check if
> the
>>>> resource is busy and force it to not be?
>>>> zspitzer wrote:
>>>>> Are you closing your featureReader? show us some more code :)
>>>>> Also, you probably want to be using session resources rather than
>>>>> library resources
>>>> View this message in context:
> http://www.nabble.com/Please-try-your-operation-later-as-the-resource-wa
> s-busy-tp16392736p17280519.html
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> s-busy-tp16392736p17282025.html
> No virus found in this incoming message.
> Checked by AVG.
> Version: 8.0.101 / Virus Database: 270.4.1/1522 - Release Date: 6/27/2008 8:27 AM
