[mapguide-users] Selection Issue (FeatureReader only grabbing20items)
Maksim Sestic max at geoinova.com
Mon Jul 21 11:46:43 EDT 2008
You don't, but MG does.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Monday, July 21, 2008 17:42
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Selection Issue (FeatureReader only
grabbing20items)
I'm using MySQL, though at this point in the process I'm not doing anything
with the database.
Maksim Sestic wrote:
> Yes, happens to me too here and there. No exceptions thrown, no errors
> reported. I'm not talking to MG via XML (did that before), rather via
> JSON web services being called from client's JavaScript. I also
> noticed described reader mishaps while using Autodesk's MS SQL
> provider. What RDBMS are you using?
> Regards,
> Maksim Sestic
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Monday, July 21, 2008 17:25
> Subject: [mapguide-users] Selection Issue (FeatureReader only grabbing
> 20items)
> Hi all,
> This has just recently become a problem. I am passing the selection
> xml to a page to display parcel owner data. For an example, I select
> 256 parcels on the map. The selection xml comes over fine, with all
> 256 parcels listed.
> When I use a featureReader to get the parcel numbers from the
> features, It only get the first 20.
> Is this a setting I may have altered unintentionally, or could there
> be more to it?
> Here is the code that I am using to pull the information out from the
> selection xml:
> == function GetObjKeys($sessId,$mapName,$sel){
>   $obj_keys = '';
>     if($sel != ''){
>       InitializeWebTier();
>       $userInfo = new MgUserInformation($sessId);
>       $siteConnection = new MgSiteConnection();
>       $siteConnection->Open($userInfo);
>       $resourceService =
> $siteConnection->CreateService(MgServiceType::ResourceService);
>       $featureService =
> $siteConnection->CreateService(MgServiceType::FeatureService);
>       $map = new MgMap($siteConnection);
>       $map->Open($resourceService,$mapName);
>       $selection = new MgSelection($map,$sel);
>       if($selection != ''){
>         $layers = $selection->GetLayers();
>         if(!$layers){ $layers = $map->GetLayers(); }
>       }else{ $layers = 0; }
>       $layer = null;
>       if($layers){
>       for($i = 0; $i < $layers->GetCount(); $i++){
>         if($layers->GetItem($i)->GetName() == "parcels"){ $layer =
> $layers->GetItem($i); }
>       $queryOptions = new MgFeatureQueryOptions();
>       if($layer){
>         $layerClassName = $layer->GetFeatureClassName();
>         if($sel != ''){ $selString =
> $selection->GenerateFilter($layer,$layerClassName); }
>         $layerFeatureId = $layer->GetFeatureSourceId();
>         $layerFeatureResource = new MgResourceIdentifier($layerFeatureId);
>         $layerId = $layer->GetObjectId();
>         $queryOptions->SetFilter($selString);
>         $featureReader =
$featureService->SelectFeatures($layerFeatureResource,$layerClassName,$query
> Options);
>         $selTmp = '';
>         for($pdx=0; $pdx<$featureReader->GetPropertyCount(); $pdx++){
>           $pnm = $featureReader->GetPropertyName($pdx);
>           if($pnm == 'PARCEL_ID_'){ break; }
>           if($pnm == 'PARCELID'){ break; }
>           if($pnm == 'Key'){ break; }
>           $pnm = "";
>         if($pnm != ""){
>           while($featureReader->ReadNext()){
>             $stg = $featureReader->GetString($pnm);
>             if($stg != ""){	$obj_keys .= "'" . $stg . "'"; }
>         $obj_keys = str_replace("''","','",$obj_keys);
>     return $obj_keys;
>   }else{ return ''; }
> http://www.nabble.com/Selection-Issue-%28FeatureReader-only-grabbing-2
> 0-item
> s%29-tp18570994p18570994.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> __________ NOD32 3281 (20080718) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.eset.com
http://www.nabble.com/Selection-Issue-%28FeatureReader-only-grabbing-20-item
s%29-tp18570994p18571366.html
http://www.eset.com
