[mapguide-users] invokeurl
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jul 23 14:56:25 EDT 2008
Excellent - found it. I'll try it out in a bit...thanks!!
andrew
Kenneth Skovhede, GEOGRAF A/S wrote:
> Not 100%, but the call is window.open, and I think its the function
> OpenUrl in mainframe.templ, around line 706.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> I'd thought of that, but I'd have to change quite a few things to
>> make that method work on all of my sites....so I'm looking for the
>> easy way...I'm sure it's a matter of editing a file - I just have no
>> idea where or which one.
>> Andrew
>> nclayton wrote:
>>> You could invoke a url that generates the popup window for you. Though, there
>>> may be an easier way.
>>> andrew.demerchant wrote:
>>>> Is there a way to modify the InvokeURL command to have it open a window
>>>> with scrollbars and toolbars? Right now, if you tell it to open in a new
>>>> window, that window never has scrollbars or toolbars. I need to turn
>>>> those on somehow. I've looked through the AJAX viewer php files, but
>>>> can't find the spot that I'd change.
>>>> Andrew
>>>> 	*Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited<http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> 	*Andrew DeMerchant*
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
