[mapguide-users] Loading large amount of raster Data within MG 2.0 with GDAL Provider
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 25 06:55:41 EDT 2008
I'm pretty sure the tile index config file works for FDO 3.3.* as well.
What errors are you getting? Have you tried the debug instructions to
see if there are more errors?
You can try to build an index file with Maestro, but you have to use the
preview build (r3235)
http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
After you build it, you can examine the config file, and see if any of
the images failed.
If they failed, they will have a bounding box of 1000000, 1000000,
-1000000, -1000000.
Regards, Kenneth Skovhede, GEOGRAF A/S
wkhattak skrev:
> Hi,
> I am having no success in loading a large amount of raster data using GDAL
> (3.3.0). On experimental basis, it works with a small amount of data (I ahve
> got tiff based images). I have also tried by creating the tile index Config
> file but it looks like that it only applies to 3.2.0. It's the same story
> with Autodesk's raster provider, only works with a small amount of data.
> regards,
> W Khattak
