[mapguide-users] Loading large amount of raster Data within MG 2.0 with GDAL Provider
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 25 07:42:36 EDT 2008
In the command prompt write:
set CPL_DEBUG=ON
then
mgserver.exe /interactive
Regards, Kenneth Skovhede, GEOGRAF A/S
wkhattak skrev:
> I am trying to run the server in interactive mode, however, it looks like
> that the CPL_DEBUG environment var is not set up on my machine.If I want to
> set it up manually, what should be its value?
> regards,
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> I'm pretty sure the tile index config file works for FDO 3.3.* as well.
>> What errors are you getting? Have you tried the debug instructions to
>> see if there are more errors?
>> You can try to build an index file with Maestro, but you have to use the
>> preview build (r3235)
>> http://trac.osgeo.org/mapguide/wiki/maestro/Downloads
>> After you build it, you can examine the config file, and see if any of
>> the images failed.
>> If they failed, they will have a bounding box of 1000000, 1000000,
>> -1000000, -1000000.
>> wkhattak skrev:
>>> Hi,
>>> I am having no success in loading a large amount of raster data using
>>> GDAL
>>> (3.3.0). On experimental basis, it works with a small amount of data (I
>>> ahve
>>> got tiff based images). I have also tried by creating the tile index
>>> Config
>>> file but it looks like that it only applies to 3.2.0. It's the same story
>>> with Autodesk's raster provider, only works with a small amount of data.
>>> regards,
>>> W Khattak
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080725/44a7ccc2/attachment.html
