[mapguide-users] MSSQL 2000 Support
Jackie C. Ng jumpinjackie at gmail.com
Sat Jul 26 23:57:58 EDT 2008
You can only connect to a MSSQL 2000 database using the ODBC FDO provider,
meaning you can only use the database for points, or for feature joins.
If you want to use MSSQL 2000 as a spatially-enabled database, I think you
will need the Enterprise version as that has a provider (Autodesk.SqlServer
provider) for such functionality.
- Jackie
jkattampally wrote:
> Hi,
> Is there anyone out there using MSSQL 2000 as the data repository for MGOS
> 2.0?. Just wanted to make sure MGOS 2.0 can connect to MSSQL 2000 with out
> any problems. Would it need any additional config. or plugin, to make it
> connect or can it connect with the basic windows install?
> Thanks
> Joe
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/MSSQL-2000-Support-tp18658836p18673161.html
