[mapguide-users] How do i load raster in MGOS 2?
wkhattak Wajid.Khattak at keynetix.com
Tue Jul 29 07:35:49 EDT 2008
hi,
Did you create your data resource using the script (GDAL notes webpage) or
did you create it manually? If you created it manually then yeah the
Download option would be greyed out, in that case create it using the script
(php page that you need to download and put it in your www folder). The
extents are the lower left & upper right coords as they appear in the
'Initial View' within the map tab.
regards,
W Khattak
View this message in context: http://www.nabble.com/How-do-i-load-raster-in-MGOS-2--tp18648843p18710257.html
