[mapguide-users] Publish Map to MGOS error
Tom Fukushima
tom.fukushima at autodesk.com
Wed Jul 30 17:57:13 EDT 2008
The access log entries don't look good. I just tried this on a 2009 configuration, and there should be a "MoveResource" operation to create the folder, some enumerate resources ops, and later an ApplyResourcePackage op.
Things to try:
* Try removing layers from you Map drawing and see which ones might be causing the problem.
* Try connecting using Administrator.
Tom
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ray Holtz
Sent: Wednesday, July 23, 2008 5:35 PM
To: MapGuide Users Mail List
Subject: [mapguide-users] Publish Map to MGOS error
Hello, we are having a problem publishing a map from AutoCAD Map3D 2008
to MGOS1.2. We go to File>More Plotting Options>Publish to Autodesk
Mapguide and then log into the MGOS server. MGOS is running on Ubuntu
7.04. We make a new folder for the new map, and then 'Make a new copy
of the resources'. It thinks and says 'Communicating with site'. Then
it fails, the dialog box says:
Publishing map: Default
Prepared drawing source data for layer: Map Base
Sending data to server
______________________________________________
PUBLISH CANCELLED:
- Failed to finish this operation or the current session has been Expired.
Unable to publish 1 layer
1 error
I have attached the Access log, Admin log, and Trace log for the time
that I was trying to publish this map. No other logs had any entries
for the times that I was trying to publish this.
We have published a map using this process before, and I don't remember
changing anything that would or would not cause this issue.
Any help is greatly appreciated.
Thanks!
