[mapguide-users] Fusion map insists onrefreshing map on selection, and clear selection...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jul 31 10:15:14 EDT 2008
Ya, I see that it's fixed! It did break a few templates though, it seems
- but I may just need to rebuild my Fusion Map in Maestro/Studio.....It
definitely does seems better. If I can get my templates working again
now, I may be able to use fusion for my clients! Thanks!
Berdel, Brian wrote:
> And the latest trunk does fix that issue!  Just be careful  if you use
> setSelection with the latest version...you have to update some of the
> code for it to work.   It is documented here
> http://trac.osgeo.org/mapguide/ticket/630
> Brian
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Thursday, July 31, 2008 9:44 AM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Fusion map insists onrefreshing map on
> selection,and clear selection...
> Thanks Jason - I guess that's not so hard! I'll give it a
> shot...thanks again!
> Andrew
> Jason Birch wrote:
> Hi Andrew,
> While I believe that it would be possible to set up nightly builds for
> Fusion, it would be more work for you to deal with these than with
> SVN. It might look daunting, but SVN is really easy to work with:
> - install TortoiseSVN (http://tortoisesvn.net/downloads)
> - rename your existing fusion directory to fusion_old
> - create a new empty fusion directory
> - right-click on the new fusion directory and
>   - choose SVN Checkout
>   - enter http://svn.osgeo.org/fusion/trunk/ into the URL field
>   - click on OK (or something like that)
> - copy all of the contents of
>   - fusion_old/templates/mapguide    to
>   - fusion/templates/mapguide
> That should just work, and now any time you want to update to the
> latest build, you can right-click on the fusion directory and say "SVN
> Update".  You don't ever need to re-copy the templates, and for the
> cost of these few extra steps staying on top of trunk is now a
> single-click effort.  If you need to go back to the original fusion
> for some reason, you can just rename the directories back with no ill
> effects.
> If you do go down this path, I think someone mentioned on the Fusion
> list that you might need to add application/json to the MIME types if
> you're running Windows Server 2003 with IIS.
> Jason
> *From:* Andrew DeMerchant
> That and the SVN are simply too much extra work for those of us just
> interested in testing stuff. The SVN for Fusion has so many files and
> folders, it's not possible for someone to just 'know' where to put
> stuff on their system to make it work. A zip file would be nice, like
> on the GetIt page.....Why can't the build scripts be automated to
> build stuff every night/week and then put it somewhere? That seems
> like a pretty simple thing to do, provided we have access to a server
> somewhere.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org  <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
