[mapguide-users] 2.0.1 install server 2003
nclayton nclayton at gmail.com
Thu Jul 31 11:19:55 EDT 2008
you shouldn't need to move your php.ini file from the php folder under
WebServerExtensions
remove all other copies of php.ini you may have on the system.
you can create a file in the mapviewer folder and give it a .php extension
and inside type:
<? phpinfo(); ?>
save and then navigate to this page in a browser and it will give you the
php configuration settings.
"Loaded Configuration File" should be set to the php folder under
WebServerExtensions
Berdel, Brian wrote:
> I am actually using the .net bundled config.  I have no other PHP
> versions setup.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
> Sent: Thursday, July 31, 2008 8:47 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] 2.0.1 install server 2003
> Did you use the bundled PHP package or one that you downloaded?
> If you haveother PHP versions set up, you may need to remove them to
> keep
> MapGuide from getting confused.
>> Hello all,
>> I have 2.0.1 installed on my development machine, but have been unable
>> to get the web server extensions to function correctly on server 2003
> R2
>> Getting Fatal error: Call to undefined function MgInitializeWebTier()
> in
>> C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapadmin\login.php
>> on line 70
>> When going to the admin page (with errors turned on)
>> I have moved my php.ini file to the windows directory and checked the
>> registry setting
>> Fatal error: Call to undefined function MgInitializeWebTier() in
>> C:\Program
>> on line 70
>> Brian Berdel
>> Applications Development Manager
>> McMahon Associates, Inc.
>> 425 Commerce Drive, Suite 200
>> Fort Washington, Pennsylvania 19034
>> p: 215.283.9444
>> f:  215.283.9858
>> brian.berdel at mcmtrans.com
>>   <http://www.mcmtrans.com>
>>    New England  |  Mid-Atlantic  |  Florida
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/2.0.1-install-server-2003-tp18742286p18753793.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/2.0.1-install-server-2003-tp18742286p18756959.html
