[mapguide-users] Fusion map insists onrefreshing map on selection, and clear selection...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jul 31 14:13:08 EDT 2008
That did it. I did a find and replace in all of my index.html files in
the templates...Thanks!
Andrew
Paul Spencer wrote:
> One thing that has changed in the templates is that
> OpenLayers.String.translate has changed to OpenLayers.i18n - the
> translate function is used in some of the templates, that is likely a
> good place to start.
> Cheers
> Paul
> On 31-Jul-08, at 10:15 AM, Andrew DeMerchant wrote:
>> Ya, I see that it's fixed! It did break a few templates though, it
>> seems - but I may just need to rebuild my Fusion Map in
>> Maestro/Studio.....It definitely does seems better. If I can get my
>> templates working again now, I may be able to use fusion for my
>> clients! Thanks!
>> Berdel, Brian wrote:
>>> And the latest trunk does fix that issue!  Just be careful  if you
>>> use setSelection with the latest version…you have to update some of
>>> the code for it to work.   It is documented here
>>> http://trac.osgeo.org/mapguide/ticket/630
>>> Brian
>>> From: mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>>> DeMerchant
>>> Sent: Thursday, July 31, 2008 9:44 AM
>>> To: MapGuide Users Mail List
>>> Subject: Re: [mapguide-users] Fusion map insists onrefreshing map on
>>> selection,and clear selection...
>>> Thanks Jason - I guess that's not so hard! I'll give it a
>>> shot...thanks again!
>>> Andrew
>>> Jason Birch wrote:
>>> Hi Andrew,
>>> While I believe that it would be possible to set up nightly builds
>>> for Fusion, it would be more work for you to deal with these than
>>> with SVN. It might look daunting, but SVN is really easy to work with:
>>> - install TortoiseSVN (http://tortoisesvn.net/downloads)
>>> - rename your existing fusion directory to fusion_old
>>> - create a new empty fusion directory
>>> - right-click on the new fusion directory and
>>>   - choose SVN Checkout
>>>   - enter http://svn.osgeo.org/fusion/trunk/ into the URL field
>>>   - click on OK (or something like that)
>>> - copy all of the contents of
>>>   - fusion_old/templates/mapguide    to
>>>   - fusion/templates/mapguide
>>> That should just work, and now any time you want to update to the
>>> latest build, you can right-click on the fusion directory and say
>>> "SVN Update".  You don't ever need to re-copy the templates, and for
>>> the cost of these few extra steps staying on top of trunk is now a
>>> single-click effort.  If you need to go back to the original fusion
>>> for some reason, you can just rename the directories back with no
>>> ill effects.
>>> If you do go down this path, I think someone mentioned on the Fusion
>>> list that you might need to add application/json to the MIME types
>>> if you're running Windows Server 2003 with IIS.
>>> Jason
>>> From: Andrew DeMerchant
>>> That and the SVN are simply too much extra work for those of us just
>>> interested in testing stuff. The SVN for Fusion has so many files
>>> and folders, it's not possible for someone to just 'know' where to
>>> put stuff on their system to make it work. A zip file would be nice,
>>> like on the GetIt page.....Why can't the build scripts be automated
>>> to build stuff every night/week and then put it somewhere? That
>>> seems like a pretty simple thing to do, provided we have access to a
>>> server somewhere.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> <mime-attachment.gif>
>>> Andrew DeMerchant
>>> Computer Technologist
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> GEMTEC Limited
>>> 191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>> <logo.gif>
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
