[mapguide-users] Mgos reading oracle column incorrectly
Haris Kurtagic
haris at sl-king.com
Mon Jun 2 07:13:55 EDT 2008
Yes, King.Oracle works as you described.
It maps Oracle Char ( length 1 ) to FDO byte data type. There is no
single char type in FDO, only string data type.
One of quick solutions would be to create view or change column type to
either have length more than 1 or use varchar.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Marius_360
Sent: Monday, June 02, 2008 9:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mgos reading oracle column incorrectly
Hi All
I have an Oracle table with a geometry column, which I display in mgos
successfully. But one of the columns are not being read correctly, for
instance the column contains the values 'W', 'H', 'S' and so on, but
mgos is
reading it as '82', '83' ect.
This is a big problem as my layer filter is built from this column and
there
is a show info with the values of this column, so it is not working. I
am
using mgos 2.0 and Oracle 10gR2 on Windows server 2003 and IIS with the
latest Sl-king providers, the column data type is CHAR(1).
Anybody got any ideas as this is a really big problem,
Regards,
Marius
View this message in context:
http://www.nabble.com/Mgos-reading-oracle-column-incorrectly-tp17595252p
17595252.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
