[mapguide-users] Shareable query
Rahul
unicorn_admirer at yahoo.com
Tue Jun 3 08:12:10 EDT 2008
Hi ,
Do the Following to get going with the Sample GT Application on MGOS2.1.0 (API Change).
1.Query Task--Change the query.php File
2.Theme Task-No Change works perfectly ok
3.Markup Task-Change the markupeditor.php File
1.Change thefunction Execute() in the query.php file at C:\ProgramFiles\MapGuideOpenSource2.\WebServerExtensions\www\phpviewersample\query\classes
function Execute()
$result = array();
$resourceService =
$this->site->CreateService(MgServiceType::ResourceService);
$map = new MgMap();
$map->Open($resourceService, $this->args['MAPNAME']);
$layer = $map->GetLayers()->GetItem($this->args['LAYERNAME']);
$featureService =
$this->site->CreateService(MgServiceType::FeatureService);
$resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
$featureClass = $layer->GetFeatureClassName();
$featureGeometry = $layer->GetFeatureGeometryName();
// Initialize the coordinate system transform
$schemaAndClass = explode(":", $featureClass);
$classDef = $featureService->GetClassDefinition($resId,
$schemaAndClass[0], $schemaAndClass[1]);
$geomProp = $classDef->GetProperties()->GetItem($featureGeometry);
$spatialContext = $geomProp->GetSpatialContextAssociation();
$csTransform = null;
$csInverseTransform = null;
$coordSysFactory = new MgCoordinateSystemFactory();
$scReader = $featureService->GetSpatialContexts($resId, false);
while ($scReader->ReadNext() && $csTransform == null)
if ($scReader->GetName() == $spatialContext)
$source =
$coordSysFactory->Create($scReader->GetCoordinateSystemWkt());
$target = $coordSysFactory->Create($map->GetMapSRS());
$csTransform=$coordSysFactory->GetTransform($source, $target);
$csInverseTransform=$coordSysFactory->GetTransform($target, $source);
//$csTransform = new MgCoordinateSystemTransform($source, $target);
//$csInverseTransform = new MgCoordinateSystemTransform($target, $source);
3. Change function GetTransform() in the markupeditor.php file at
C:\ProgramFiles\MapGuideOpenSource2.\WebServerExtensions\www\phpviewersample\markup\classes
$resourceService =
$map = new MgMap();
$source = $coordSysFactory->Create($map->GetMapSRS());
$target = $coordSysFactory->Create(MarkupManager::LL84WKT);
return $coordSysFactory->GetTransform($source, $target);
// return new MgCoordinateSystemTransform($source, $target);
Cheers
Max !!
----- Original Message ----
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Tuesday, June 3, 2008 11:52:21 AM
Subject: RE: [mapguide-users] Shareable query
querycontroller.php is erroring out on you on the site you posted earier -- 127.0.0.1 didn't work for me :)
Anything in the apache error log, or in the php error log (assuming you have it enabled)?
Once you get this all working, it would be great to see a trac ticket describing what was wrong with the GT sample, and what you did to fix it:
http://trac.osgeo.org/mapguide/wiki/SubmitTicket <http://trac.osgeo.org/mapguide/wiki/SubmitTicket>
Jason
Subject: [mapguide-users] Shareable query
Now I working on query functionality. It can't to query the result. DO you
have idea? I have captured a sort of access.log file:
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080603/9dcaf55c/attachment.html
