[mapguide-users] Geometry not shown
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Jun 4 15:37:05 EDT 2008
I think there are some companies that offer paid support for MapGuide
Open Source.
There are a couple of things you can try.
1. When you create the Feature Source, what happens when you press the
"Test Connection" button?
2. When you create the layer, can you see anything in the "Schema" and
"Geometry" columns?
3. When you create the layer, you must create a scale range.
I suggest you set minimun to 0 and maximum to infinity.
4. On the layer, you must select either point, line or area.
5. In whichever you choose in step 4, you must make sure it is visible
(ea. make it bright red with a black border)
6. When you create the map, there is a button saying "Set extent to
selected layer coordinates".
When you press it, make sure the coordinates are what you expect.
If not, you may have to set up a coordinate override on the Feature Source.
If you are having trouble with step 3, 4 or 5, I suggest you download
version 1.0.7 of Maestro (previously MapStudio):
http://trac.osgeo.org/mapguide/wiki/maestro
Hope that helps you out, otherwise, please write again.
Regards, Kenneth Skovhede, GEOGRAF A/S
katia.goes at katiagoes.com skrev:
> Hi.
> I still have problems with mapstudio.I connected a FDO like SHP,
> contained a geometry like area and a arge table contained data (DBF).
> During Map´s development it seams easy to create:
> a) Connect a SHP file;
> b) create a layer;
> c) Create a Map e insert a layer created on step b;
> d) create a layout.
> OBS: I call to Autodesk and they suggest create a Map first. I create
> e nothing change teh situation.
> After this, I thing so, that the geometry must be shown. The menu at
> left side the layer is shown, but the geometry not. When I setup zoom
> level, this same layer appear and desappear according to scale. But
> geometry not appear.
> I´m using UTM 23 coordinate - south american sad69 - and limits my
> projets as:
> Lower left X - 730954 Y - 7537346
> upper right X - 759069 Y - 7566373
> Is possible that I have problems with pluggin like ajax etc?
> To use mapstudio I installed . NET FRAMEWORK 1.1
> Mapguide server - 2.0
> Mapguider Extension 2.0
> Mapstudio 1[1].0.6
> Is there any place that I can send my files to be checked?
> Thanks
> Kátia Góes
> Especialista em SIG e Analista Ambiental
> www.katiagoes.com / 21-8308-0325
> Kátia Góes
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080604/770c45eb/attachment.html
