[mapguide-users] Fusion tiled and dynamic layers same map
Leandro R
learonco at gmail.com
Wed Jun 4 16:49:48 EDT 2008
Hello list...
I'm running MGOS 2.0.1 with bundled Apache. Windows Server 2003 R2.
There is a map that works fine with PHPViewer but doesn't with Fusion.
The Map has three BaseGroupLayer (TileCache) and many dynamic layers. One
baseLayer come from WMS and the others (cached and dynamic) from ArcSDE 9.1.
I've tested a map only with dynamic layers and worked fine; and the
sheboygan tiled sample that has worked fine too.
Does Fusion acept both tiled and dynamic layers in the same map?
Is there any way to solved this?
Thanks
Leandro
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080604/d10a0cd5/attachment.html
