[mapguide-users] MGOS2.0.1 & Raster Files Performance
Rahul unicorn_admirer at yahoo.com
Thu Jun 5 08:25:17 EDT 2008
Hi All,
            I am using PHP+Apache+Windows Server 2003  and i have around 50 ecw files in one folder, i created the Image Feature Source using the OSGeo.Gdal FDO provider and able to view the raster data overlaid with the vector data but the problem is about the performance and sometime it use to fail to stylize layer due to Cannot create any more connections to the OSGeo.Gdal FDO provider  as well as the server also use to give the error  Please try your operation later as the resource was busy: Library://Raster/Data/Images.FeatureSource .
How to solve the issue.
Thks
Max !!
Error
<2008-06-05T15:41:04>    Administrator
 Error: Failed to stylize layer: Image
        Cannot create any more connections to the OSGeo.Gdal FDO provider.
 StackTrace:
  - MgMappingUtil.StylizeLayers line 775 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\mapping\MappingUtil.cpp Failed to stylize layer: Image
<2008-06-05T15:42:26>    Administrator
 Error: Please try your operation later as the resource was busy: Library://Raster/Data/Images.FeatureSource
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation line 80 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
  - MgOpDeleteResource.Execute line 97 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\OpDeleteResource.cpp
  - MgServerResourceService.DeleteResource line 750 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\resource\ServerResourceService.cpp
  - MgServerFeatureService.NotifyResourcesChanged line 1457 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerFeatureService.cpp
  - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\common\manager\FdoConnectionManager.cpp Please try your operation later as the resource was busy: Library://Raster/Data/Images.FeatureSource
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080605/f536bdcf/attachment.html
