[mapguide-users] MGOS2.0.1 & Raster Files Performanc
Maksim Sestic
max at geoinova.com
Thu Jun 5 11:29:28 EDT 2008
Hi Zac,
Could you confirm this happening on MGOS 2.0.1 too? I'm experiencing the
same problem on MGE 2009 (based on MGOS 2.0.0 with some additions, but
without any fixes though). The whole rasters thing drives me nuts for a
while :-)
Regards,
Maksim Sestic
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Thursday, June 05, 2008 17:14
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS2.0.1 & Raster Files Performanc
in my experience, rasters in mapguide are currently and have have been for a
while somewhat broken.
they work initially and then fall over rather quickly
the debug info on the wiki page makes absolutely no difference
z
On Thu, Jun 5, 2008 at 11:50 PM, Rahul <unicorn_admirer at yahoo.com> wrote:
> Hi Gunter,
> I already tried Creating Tile Index Config Files
> after changing the parameters for the MGOS2.0.1 and it use to create
> new connection for the Image Feature source .I can preview the layers
> using MapGuide Studio2009 but after using Tile Index as well as built
> in pyramids for ecw file ,I still use to get the same errors as below.
> * Out of memory (Infact i tried to run some batch file as well as
> another script to monitor the memory usage and restart the mapguide
> service to avoid memeory leakage.)
> * Failed to stylize layer
> * with some ecw files when zoom at certain scales no image display and
> get the error (Cannot create any more connections to the OSGeo.Gdal
> FDO
> provider)
> Thks
> Max !!
> ----- Original Message ----
> From: Gunter Becker <gunter.becker at CSOGIS.DE>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, June 5, 2008 8:05:11 PM
> Subject: Re: [mapguide-users] MGOS2.0.1 & Raster Files Performance
> Hi Max,
> please habe a look at http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
> Creating Tile Index Config Files . Maybe you can build a tile index
> for your ecw-files. That will minimiz the file access. But I don't
> know if this works with ecw.
> Gunter
> max_samart wrote:
>> Hi All,
>> I am using PHP+Apache+Windows Server 2003 and i have
>> around 50 ecw files in one folder, i created the Image Feature Source
>> using the OSGeo.Gdal FDO provider and able to view the raster data
>> overlaid with the vector data but the problem is about the
>> performance and sometime it use to fail to stylize layer due to
>> Cannot create any more connections to the OSGeo.Gdal FDO provider as
>> well as the server also use to give the error Please try your operation
later as the resource was busy:
>> Library://Raster/Data/Images.FeatureSource .
>> How to solve the issue.
>> Thks
>> Max !!
>> Error
>> <2008-06-05T15:41:04> Administrator
>> Error: Failed to stylize layer: Image
provider.
>> StackTrace:
>> - MgMappingUtil.StylizeLayers line 775 file
>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\ser
>> ver\src\services\mapping\MappingUtil.cpp Failed to stylize layer:
>> Image Cannot create any more connections to the OSGeo.Gdal FDO provider.
>> <2008-06-05T15:42:26> Administrator
>> Error: Please try your operation later as the resource was busy:
>> StackTrace:
>> - MgResourceServiceHandler.ProcessOperation line 80 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src
\services\resource\ResourceServiceHandler.cpp
>> - MgOpDeleteResource.Execute line 97 file
\services\resource\OpDeleteResource.cpp
>> - MgServerResourceService.DeleteResource line 750 file
\services\resource\ServerResourceService.cpp
>> - MgServerFeatureService.NotifyResourcesChanged line 1457 file
\services\feature\ServerFeatureService.cpp
>> - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
>> ver\src\common\manager\FdoConnectionManager.cpp Please try your operation
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/MGOS2.0.1---Raster-Files-Performance-tp17668649p
> 17669360.html Sent from the MapGuide Users mailing list archive at
> Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
__________ NOD32 3160 (20080605) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
