[mapguide-users] Custom Symbols...
Martin Morrison
martin.morrison at edsi.com
Thu Jun 5 12:30:36 EDT 2008
The line symbol stays, the point symbol (image) disappears. I have
resized it to a larger scale just in case, still doesn't show up. The
scale that the images cut off at is in the 6000 to 6500 range. No
errors in the logs after I got the symbol working correctly. At first I
had just the image showing up, no text, it still had the same behavior.
Martin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Thursday, June 05, 2008 11:29 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Custom Symbols...
I can't see anything immediately wrong with the symbol definitions. Does
the whole point symbol disappear, or just the image part? Did you see
any errors in the logs? What happens if you remove the image from the
point symbol (or remove the text from it)? Consider writing a bug report
for this one, so that someone can look into this further.
Traian
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Martin Morrison
> Sent: Thursday, June 05, 2008 11:15 AM
> Subject: FW: [mapguide-users] Custom Symbols...
> Any thoughts?
> Thanks,
> Martin
> From: Martin Morrison
> Sent: Wednesday, June 04, 2008 8:02 AM
> To: 'MapGuide Users Mail List'
> I have pasted the relevant parts of each file below. I have both
(line
> and symbol) on the same layer with I thought the same scales.
> >From the layer definition...
> <VectorScaleRange>
> <MinScale>100</MinScale>
> <CompositeTypeStyle>
> <CompositeRule>
> <LegendLabel>'Interstate Highways'</LegendLabel>
> <CompositeSymbolization>
> <SymbolInstance>
<ResourceId>Library://Mecklenburg_County/Layers/Interstate_Highway.Symb
> o
> lDefinition</ResourceId>
> <ParameterOverrides>
> <Override>
> <SymbolName>Shield</SymbolName>
> <ParameterIdentifier>ROADNAME</ParameterIdentifier>
> <ParameterValue>ROUTE</ParameterValue>
> </Override>
> </ParameterOverrides>
> </SymbolInstance>
> </CompositeSymbolization>
> </CompositeRule>
> </CompositeTypeStyle>
> </VectorScaleRange>
> >From the symbol definition...
> <SimpleSymbol>
> <SimpleSymbolDefinition>
> <Name>Outline</Name>
> <Graphics>
> <Path>
> <Geometry>M 0.0,0.0 H 5.0 Z</Geometry>
> <LineColor>FF000000</LineColor>
> <LineWeight>2.0</LineWeight>
> </Path>
> </Graphics>
> <LineUsage>
> <VertexControl>'OverlapWrap'</VertexControl>
> <StartOffset>0</StartOffset>
> <Repeat>5.0</Repeat>
> <VertexAngleLimit>180.0</VertexAngleLimit>
> </LineUsage>
> <ParameterDefinition/>
> </SimpleSymbolDefinition>
> <RenderingPass>0</RenderingPass>
> </SimpleSymbol>
> <SimpleSymbol>
> <Name>Inner</Name>
> <Graphics>
> <Path>
> <LineColor>FF800000</LineColor>
> <LineWeight>0.9</LineWeight>
> </Path>
> </Graphics>
> <LineUsage>
> </LineUsage>
> <RenderingPass>1</RenderingPass>
> </SimpleSymbol>
> <SimpleSymbol>
> <Name>Shield</Name>
> <Graphics>
> <Image>
> <Content>
iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuSAAAAALHRFWHRDcmVhdGlvbiBUaW1
> l
> AEZy
aSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAA
> A
> CXBI
WXMAAAsSAAALEgHS3X78AAAABGdBTUEAALGPC/xhBQAAACpQTFRFxt7G///3////pc73hIT
> G
> AAD/
Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1df
> b
> koMg
DAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp0
> 0
> Cuz7
zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa
> 2
> loqz
v5uI5jiJRo35EdViqyKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTC
> K
> msjA
+UmQGjiE/16RVrVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/
> V
> 1pLH
0QljcFfYgodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213
> R
> L2zU
0zRUWMYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y
> 6
> +jho
> AQAAAAAASUVORK5CYII=
> </Content>
> <SizeX>8.0</SizeX>
> <SizeY>8.0</SizeY>
> <SizeScalable>True</SizeScalable>
> <Angle>0.0</Angle>
> <PositionX>0.0</PositionX>
> <PositionY>0.0</PositionY>
> </Image>
> <Text>
> <ResizeControl>'AddToResizeBox'</ResizeControl>
> <Content>%ROADNAME%</Content>
> <FontName>'Arial'</FontName>
> <Height>4</Height>
> <PositionX>0</PositionX>
> <PositionY>0</PositionY>
> <HorizontalAlignment>'Center'</HorizontalAlignment>
> <VerticalAlignment>'Halfline'</VerticalAlignment>
> <TextColor>FFFFFFFF</TextColor>
> </Text>
> </Graphics>
> <ResizeBox>
> <SizeX>6</SizeX>
> <SizeY>6</SizeY>
> <GrowControl>'GrowInX'</GrowControl>
> </ResizeBox>
> <LineUsage>
> <AngleControl>'FromAngle'</AngleControl>
> <VertexControl>'OverlapNoWrap'</VertexControl>
> <Angle>0</Angle>
> <StartOffset>50</StartOffset>
> <EndOffset>50</EndOffset>
> <Repeat>100</Repeat>
> </LineUsage>
> <ParameterDefinition>
> <Parameter>
> <Identifier>ROADNAME</Identifier>
> <DefaultValue>5</DefaultValue>
> <DisplayName>ROADNAME</DisplayName>
> <Description>ROADNAME</Description>
> <DataType>Integer</DataType>
> </Parameter>
> </ParameterDefinition>
> <RenderingPass>2</RenderingPass>
> </SimpleSymbol>
> Stanev
> Sent: Tuesday, June 03, 2008 5:08 PM
> There is not enough information to answer this. Is the rest of the
road
> drawn using the same symbol definition, or is it a separate one (or
> even
> a separate layer?). Normally the scale range for visibility is
> specified
> for the whole layer, so if you are seeing this with data on the same
> layer, it could be a bug.
> Traian
> > Sent: Tuesday, June 03, 2008 3:38 PM
> > Ok, next question...
> > I have the symbols working, they look great. The road symbols just
> > turn
> > off when I zoom out past about 7000 even though the road still shows
> up
> > with it's style. I don't see a parameter that controls how far in
> and
> > out the symbol displays. Where should this be changed at?
> > Thanks,
> > Martin
> > Stanev
> > Sent: Sunday, June 01, 2008 7:35 PM
> > Hi Martin,
> > You are using incorrect format for the Content tag. The
> > "data:image/png;base64," piece is not necessary, just the png
content
> > converted to base64.
> > Here is an example of correct usage:
> > <?xml version="1.0" encoding="UTF-8"?>
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
> > version="1.0.0">
> > <Name>Symbol</Name>
> > <Graphics>
> > <Image>
> > <Content>
iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAIAAAD8GO2jAAAAAXNSR0IArs4c6QAAAARnQU1
> > B
> > AACx
jwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAMl
> > J
> > REFU
SEvtlusOgCAIhe3Ne3MrSIeBaIittRz+ae18ykVYYpi8ABDDGvwtxEP82Lu6OwMECcCXkY5
> > b
> > ArwY
xBkMMM4oXS0BRhgskBWAjSGlSR3AGPuvFyvSupKEKgAZYLDZwgJCq5RRF0BWR1xmmAGaOmX
> > Y
> > AG31
zDAAetVVhhaDHwBR+baL8IJCAYslbUhTbHNthtpxX/BUzHzsWG9yfa4NQ8aNhmNQxyzqapl
> > m
> > dYnx
> > 8NgyeHZaa8Lg5ahOfJVc5K6eGCeAjySOXzZKzdKePStlhwAAAABJRU5ErkJggg==
> > </Content>
> > <SizeX>8.0</SizeX>
> > <SizeY>8.0</SizeY>
> > <Angle>0.0</Angle>
> > </Image>
> > </Graphics>
> > <PointUsage>
> > <Angle>0.0</Angle>
> > <OriginOffsetX>0.0</OriginOffsetX>
> > <OriginOffsetY>0.0</OriginOffsetY>
> > </PointUsage>
> > Thanks,
> > Traian
> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
> > Morrison
> > Sent: Friday, May 30, 2008 4:17 PM
> > Subject: [mapguide-users] Custom Symbols...
> > I'm trying to embed a PNG into a custom symbol. When I use the code
> > below I get the error shown at the bottom. If I remove this section
> it
> > works (without my PNG of course). How should the <IMAGE> tag be
> used?
> > Any clues?
> > Thanks,
> > Martin
> > ****************CODE Snippet*******************
> > <SimpleSymbol>
> > <Name>Shield</Name>
> > <Graphics>
> > <Image>
<Content>data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1
> > M
uSAAAAALHRFWHRDcmVhdGlvbiBUaW1lAEZyaSAzMCBNYXkgMjAwOCAxMzo0OTo0NyAtMDUw
> > M
BH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAACXBIWXMAAAsSAAALEgHS3X78AAAABGdBTUEA
> > A
LGPC/xhBQAAACpQTFRFxt7G///3////pc73hITGAAD/Y2PG56WE/wAA52NC56XG50JC54SE
> > 5
2OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSURBVHja1dfbkoMgDAZgf0KVtd33f91FTgUUAZOb
> > z
U2diX6TgFRYFhdY7qOTR5GHUgCat6KXt+lSO+J4DjUUcp00Cuz7zEUUZuOWAjN74wlg/zU2
> > t
gbo8nmr9to9YD47qvBSjO2c94m90GCY8S3OXn0kNXZp5p04pXa2loqzv5uI5jiJRo35EdVi
> > q
yKNRg1h/bHDtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCKmsjA+UmQGjiE/16R
> > V
rVKmkCrsVGZ4pA+qALFkco1bnEoNyK8aaVqkwTO0tfn/RtDOz4t1ebyea/V1pLH0QljcFfY
> > g
odv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213RL2zU0zRU
> > W
MYpaoEUTkRjWPKuQJq2Mq8A10DNWt6LR0/Sx1BROvTNWyWYnR8fUgmEjJSLY9If47Y6+jho
> > A
> > QAAAAAASUVORK5CYII%3D</Content>
> > <SizeX>10</SizeX>
> > <SizeY>10</SizeY>
> > </Image>
> > ****************Error************************
> > C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\Php>php.exe
> > "C:\Mapguide_Road_Symbols\loadresources.php" "C:\Mapguide_Roa
> > d_Symbols" Library://Mecklenburg_County/Layers/
> > Reading resources files from 'C:\Mapguide_Road_Symbols'
> > Writing C:\Mapguide_Road_Symbols\Primary_Road.SymbolDefinition.xml
to
> > Library://Mecklenburg_County/Layers/Primary_Road.SymbolDefinit
> > ion
> > Writing C:\Mapguide_Road_Symbols\Roads.LayerDefinition.xml to
> > Library://Mecklenburg_County/Layers/Roads.LayerDefinition
> > Writing C:\Mapguide_Road_Symbols\Roads.SymbolDefinition.xml to
> > Library://Mecklenburg_County/Layers/Roads.SymbolDefinition
> > An exception occurred in DB XML component.
> > Error: XML Indexer: Parse error in document at line, 71, char 28.
> > Parser message: Datatype error: Type:InvalidDatatypeValueExceptio
> > n, Message:Value
'URI:(data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAE0AAAA2CAMAAAC1MuS
> > A
gMjAwOCAxMzo0OTo0NyAtMDUwMBH+gTkAAAAHdElNRQfYBR4ROShsSnc5AAAACXBIWXMAAA
> > s
3hITGAAD/Y2PG56WE/wAA52NC56XG50JC54SE52OEjX+r1gAAAAF0Uk5TAEDm2GYAAAFcSU
> > R
> > BVHja1dfbkoMgDAZgf0KVtd33f91FTgUUAZObzU2diX6TgFRYFhdY7qOTR5G
HUgCat6KXt+lSO+J4DjUUcp00Cuz7zEUUZuOWAjN74wlg/zU2tgbo8nmr9to9YD47qvBSjO
> > 2
> > c94m90GCY8S3OXn0kNXZp5p04pXa2loqzv5uI5jiJRo35EdViqyKNRg1h/bH
DtpoWvEhAXnuJBP0DbZXS3PumRTQEjYQ0v7JktLROJTCKmsjA+UmQGjiE/16RVrVKmkCrsV
> > G
Ygodv3SXmZ2Keo3oGOFwT89zU2K2qjfmxm+D0Lea54W6pg8VuR1aZrk4wN+V1213RL2zU0z
> > R
> > LY9If47Y6+jhoAQAAAAAASUVORK5CYII%3D)' is not encoded in Base64 .
> > Exception occurred in method
> MgResourceDefinitionManager.UpdateDocument
> > at line 601 in file d:\buildforgeprojects\mapguide_open_sour
ce_v2.0\build_27.16\mgdev\server\src\services\resource\ResourceDefiniti
> > o
> > nManager.cpp
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
