[mapguide-users] Fusion SingleTile
Zac Spitzer
zac.spitzer at gmail.com
Thu Jun 5 22:07:44 EDT 2008
On Fri, Jun 6, 2008 at 3:33 AM, Berdel, Brian <brian.berdel at mcmtrans.com> wrote:
> I understand that, my map is a combination of Tiled / base layers and
> regular.
> But it does not seem to be tiling anything unless they are all placed in
> base layer group and I set that parameter to false. Is that how it is
> supposed to work? If so, that is fine, I just want to understand the
> functionality.
yep what your describe there is correct, that's how it's meant to work...
> Either way, the username and password comes up for every tile it
> creates.
> Thanks,
> -Brian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Thursday, June 05, 2008 11:18 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Fusion SingleTile
> single tile means render on demand, you need to put them into a tiled
> map to
> get a cached result
> z
> On Thu, Jun 5, 2008 at 11:45 PM, Berdel, Brian
>> Anyone on this? Rasters take way too long to load when using single
> tile...
>> Brian
>> ________________________________
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
> Brian
>> Sent: Wednesday, June 04, 2008 9:35 AM
>> Subject: [mapguide-users] Fusion SingleTile
>> Has anyone else tried setting the SingleTile Parameter for a map to
>> <SingleTile>false</SingleTile>
>> After doing so and then trying to load the map, it asks me for my
> password
>> for everytile, then loads primarily blank tiles...
>> Thanks,
>> -Brian
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
