[mapguide-users] how to set selected feature at client in fusion???
foolfish
xjimmyshcn at sohu.com
Sun Jun 8 22:17:16 EDT 2008
my problem is in tradition method (not use fusion), i can select feature at
server, and display the selected feature at client。
but in fusion,the follow line is failed:
parent.parent.SetSelectionXML(selectionXML);
parent.parent.mapFrame.Refresh();
my question is how to setSelection at client in fusion?:confused:
[at server]:i define a function to select Feature,and return a selectionXML
public void CreateSelectionXML(String queryLayer, String queryString,String
map_name)
MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
MgFeatureService featureService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
MgMap map = new MgMap();
map.Open(resService, map_name);
MgLayer layer = (MgLayer)map.GetLayers().GetItem(queryLayer);
MgResourceIdentifier resId = new
MgResourceIdentifier(layer.GetFeatureSourceId());
MgFeatureQueryOptions queryOption = new MgFeatureQueryOptions();
queryOption.SetFilter(queryString);
MgFeatureReader featureReader = featureService.SelectFeatures(resId,
queryLayer, queryOption);
MgSelection selection = new MgSelection(map);
selection.AddFeatures(layer, featureReader, 0);
OutputSelectionInHTML(selection, featureService, queryLayer);
selectionXML = selection.ToXml();
[at client]:
string sessionID = Request.Form.Get("SESSION");;
String queryString = "ID='"+ Request.Form.Get("ID"); +"'";
String queryLayer = Request.Form.Get("LAYER_NAME");
String map_name = Request.Form.Get("MAP_NAME");
InitializeWebTier(Request);
onnectToServer(sessionID);
CreateSelectionXML(queryLayer,queryString,map_name );
String selectionXML = utility.SelectionXML;
<script type="text/javascript" >
function onPageLoad() {
var selectionXML = '<% = selectionXML %>';
</script>
<body onload="onPageLoad()" >
</body>
View this message in context: http://www.nabble.com/how-to-set-selected-feature-at-client-in-fusion----tp17725343p17725343.html
