[mapguide-users] Running Search query from Task Pane in Fusion
Rahul
unicorn_admirer at yahoo.com
Mon Jun 9 06:37:38 EDT 2008
Hi All,
I am trying to migrate my application onto fusion(MGOS2.0.1) although i managed to add maps and other basic functions ,overview map etc but i like to add my different customized search code into the fusion task pane which use to perform search and then return results in the same task pane and when i click on zoom icon, it use to select the feature and returns the info of the feature (Its working in the MGOS2.0.1 but i don't know how to get going into the Fusion-I tried adding the task in the task pane same as MapGuide Open Source and gave the path for the query file but it use to show file not found error).
Thks
Max !!
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/f981a456/attachment.html
