[mapguide-users] Calling viewer api functions from the main page
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jun 9 07:50:46 EDT 2008
If you install firebug, you can inspect the code, and examine the
objects you are calling:
http://www.getfirebug.com/
Next step would be to look at "MapGuide Developers Guide" page 19:
http://mapguide.osgeo.org/2.0/documentation.html
You can see how the viewer frames are laid out, and see what
"parent.parent" points to.
Page 18 describes what the frames are for and page 20-25 describe
concrete cases.
Regards, Kenneth Skovhede, GEOGRAF A/S
A H skrev:
> sadly this doesn't work in Firefox. have anyone done this in Firefox?
> uXuf wrote:
>> Okay thanks. parent.viewerFrame.mapFrame works like a charm!
>> uXuf
>> Ivan Milicevic-3 wrote:
>>> try parent.viewerFrame.mapFrame.Refresh(); od
>>> window.frames.mapFrame.Refresh();
>>> ________________________________
>>> From: mapguide-users-bounces at lists.osgeo.org on behalf of uXuf
>>> Sent: uto 8.1.2008 22:43
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] Calling viewer api functions from the main page
>>> Hi all, I am trying to access the Viewer API functions from the main page
>>> of my application, i.e. the page that has the WebLayout embedded (or the
>>> iframe). I cannot seem to grab the exact frame from which these functions
>>> would be accessible. I tried using
>>> document.getElementById("viewerFrame").GetMapFrame() (viewerFrame is the
>>> name of the iframe) putting it in the onload function of the iframe but
>>> it returns "Object doesn't support this property or method". Can anyone
>>> help me in this regard? Thanks! uXuf
>>> View this message in context: Calling viewer api functions from the main
>>> page
>>> <http://www.nabble.com/Calling-viewer-api-functions-from-the-main-page-tp14699670s16610p14699670.html>
>>> Sent from the MapGuide Users mailing list archive
>>> <http://www.nabble.com/MapGuide-Users-f14845.html> at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/e58bc5e1/attachment.html
