[mapguide-users] Layer Control | fusion
Paul Spencer pagameba at gmail.com
Mon Jun 9 12:58:56 EDT 2008
Actually, that's not quite true - an API to control layer and group
visibility via the Map object does exist on the client side but I'm
not sure how easy it is to use - right now, the legend widget uses it.
Paul
On 9-Jun-08, at 12:55 PM, Mike Adair wrote:
> Currently this is only possible by altering the Map object on the
> server side.
> Mike
> Berdel, Brian wrote:
>> Is it possible to turn layers on and off client side? Or do you
>> have to use server side code?
>> Thanks,
>> Brian
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
