[mapguide-users] Layer Control | fusion
Berdel, Brian
brian.berdel at mcmtrans.com
Mon Jun 9 14:17:56 EDT 2008
It is possible, there is a show function in the fusion library.
var mapWidget = Fusion.getWidgetById('Map');
var layer = mapWidget.aMaps[0].getLayerByName('Parcels');
layer.show();
Thanks,
Brian
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
Brian
Sent: Monday, June 09, 2008 1:02 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Layer Control | fusion
Thanks, I was going to look at that.
-Brian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Monday, June 09, 2008 12:59 PM
Subject: Re: [mapguide-users] Layer Control | fusion
Actually, that's not quite true - an API to control layer and group
visibility via the Map object does exist on the client side but I'm
not sure how easy it is to use - right now, the legend widget uses it.
Paul
On 9-Jun-08, at 12:55 PM, Mike Adair wrote:
> Currently this is only possible by altering the Map object on the
> server side.
> Mike
> Berdel, Brian wrote:
>> Is it possible to turn layers on and off client side? Or do you
>> have to use server side code?
>> Thanks,
>> Brian
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
