[mapguide-users] Fusion map insists on refreshing map
on selection, and clear selection...
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Mon Jun 9 16:05:40 EDT 2008
Actually, in MapGuide OS 1.2.0 the selection is a part of the image.
So any selection/de-selection will require the map to be redrawn completely.
In MGOS 2.0.0 there was an optimization that enables an application to
retrieve the selection as a transparent PNG.
While the transition effects in OL 2.6 will visually minimize the
flickering, I would say that supporting the selection as a separate
image would be of great use in fusion.
This is especially true when the underlying layer contains complex rasters.
I have emulated the seperate layer for MGOS 1.2.0 by keeping a dummy
copy of the map where I turn on all the layers, select, and turn all
layers off.
The dummy map has transparent background, and thus renders as just the
selection.
Regards, Kenneth Skovhede, GEOGRAF A/S
Berdel, Brian skrev:
> Here is a recent post on this.
> v1.1 of Fusion will incorporate v2.6 of OpenLayers which should
> eliminate this problem and also gives us smooth transition effects for
> zoom and panning. This has already been added to the trunk version of
> fusion.
> Mike
> -----Original Message-----
> From: foolfish <xjimmyshcn at sohu.com>
> Sent: Wednesday, June 4, 2008 11:53pm
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] map flicker when refresh!!!
> when i use traditional method(not use fusion),when i show or hide a
> layer,it
> won't flickering?
> but,in fusion,i use Legend Panel (Layer Manager) to show or hide a
> layer,but
> the map is flickering obviously,it's not well~
> does anybody know how to solve the problem? wait for your help,thanks~
> http://www.nabble.com/map-flicker-when-refresh%21%21%21-tp17661479p17661479.html
> Brian
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Monday, June 09, 2008 3:29 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] Fusion map insists on refreshing map on
> selection,and clear selection...
> Just wondering if there's a way to stop fusion maps from redrawing the
> map everytime a user selects / deselects something? This doesn't
> happen using the AJAX browser...does this happen for anyone else?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
Skipped content of type multipart/related
