[mapguide-users] Fusion mapFrame
foolfish xjimmyshcn at sohu.com
Mon Jun 9 23:51:09 EDT 2008
window.top.Fusion.getWidgetById('Map').redraw() can refresh the map ,but the
Legend Pane doesn't be refreshed.
window.top.Fusion.getWidgetById('Map').reloadMap() can refresh both map and
legend panel,but it's too slow:(
another method:
parent.document.getElementById('Map').widget.aMaps[0].redraw();
reference C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\fusion\MapGuide\MapGuideViewerApi.js
Berdel, Brian wrote:
> I meant Viewer API...
> ________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
> Brian
> Sent: Monday, May 05, 2008 1:25 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] Fusion mapFrame
> Or...maybe a better question would be how would I go about refreshing a
> map or using the web api from the task frame? Is it still done the same
> way as the ajax viewer?
> Brian
> Sent: Monday, May 05, 2008 12:58 PM
> Subject: [mapguide-users] Fusion mapFrame
> How do you access the mapFrame from the TaskPane in Fusion?  Tried
> parent.parent.mapFrame, parent.mapFrame, mapFrame, etc... Keeps giving
> me a javascript error telling me it is not an object
> Thanks,
> -Brian
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Fusion-mapFrame-tp17066107p17747296.html
