[mapguide-users] Running Search query from Task Pane in Fusion
Rahul unicorn_admirer at yahoo.com
Tue Jun 10 02:31:34 EDT 2008
                  Thanks for Lot of Details let me go through and try the steps to see how i can migarate the same application on Fusion+MapGuide.I have some more questions reagrding the same:
1. How to find the fusion name-like xyz_fusion4845627ed9705
2. Can you elaborate little bit more on the below-->
At server(? Path), after selection.ToXml() ,you should add the follow line:
selection.Save(resService, map_name);
At client, use  window.top.Fusion.getWidgetById('Map').drawMap()  to
refresh the map.
Thks
Max !
----- Original Message ----
To: mapguide-users at lists.osgeo.org
Sent: Tuesday, June 10, 2008 11:39:28 AM
Subject: Re: [mapguide-users] Running Search query from Task Pane in Fusion
1)install mapguide studio 2009, then you can create flexible weblayout. it's
for fusion.
note: you can't use base layer in map.
2)the map.open(map_name) might occrue error. the map_name is not the same as
traditional method(not use fusion),suppose the map name is asiamap , in
fusion it looks like asiamap_fusion4845627ed9705.
3)the parent.parent.mapFrame might occrue error. but you can use
parent.document.getElementById('Map').
4)parent.parent.mapFrame.Refresh() cann't be used, you can use
window.top.Fusion.getWidgetById('Map').drawMap()  to refresh map.
5)if you want to select feature,you should do:
at server, after selection.ToXml() ,you should add the follow line:
at client, use  window.top.Fusion.getWidgetById('Map').drawMap()  to
refresh the map.
max_samart wrote:
> Hi All,
>           I am trying to migrate my application onto fusion(MGOS2.0.1)
> although  i managed to add maps and other basic functions ,overview map
> etc but i like to add my different customized search code into the fusion
> task pane which use to perform search and then return results in the same
> task pane and when i click on zoom icon, it use to select the feature and
> returns the info of the feature (Its working in the MGOS2.0.1 but i don't
> know how to get going into the Fusion-I tried adding the task in the task
> pane same as MapGuide Open Source and gave the path for the query file but
> it use to show file not found error).
> Thks
> Max !!
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Running-Search-query-from-Task-Pane-in-Fusion-tp17730192p17747649.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080609/8e0a7a9a/attachment.html
