[mapguide-users] HTTP Status 500 running ajaxviewersample.jsp
gimbrogno at smartlab magnitudo9 at email.it
Wed Jun 11 09:03:27 EDT 2008
Now I have another problem... When try the to connecto to
http://127.0.0.1:8008/mapguide/javaviewersample/ajaxviewersample.jsp there
is an error!
No MapGuideJavaApi found in java.library.path
Can you help me?
Many thanks
nclayton wrote:
> Are you pointing to the right java libraries?
> I have gotten similar errors in the past using php when I did not have the
> mgos specific php library loaded.
> gimbrogno @smartlab wrote:
>> Hi, I have compiled LinuxApt with tomcat support, but when I try the java
>> example
>> http://127.0.0.1:8008/mapguide/javaviewersample/ajaxviewersample.jsp I
>> have this result:
>> type Exception report
>> message
>> description The server encountered an internal error () that prevented it
>> from fulfilling this request.
>> exception
>> org.apache.jasper.JasperException: Unable to compile class for JSP:
>> An error occurred at line: 23 in the jsp file:
>> /javaviewersample/utilityfunctions.jsp
>> MgException cannot be resolved to a type
>> 20: <%@ page import="javax.servlet.http.*" %>
>> 21: <%@ page import="org.osgeo.mapguide.*" %>
>> 22: <%!
>> 23: void InitializeWebTier() throws MgException
>> 24: {
>> 25:     String realpath = getServletContext().getRealPath("/");
>> 26:     // Initialize web tier with the site configuration file.  The
>> config
>> An error occurred at line: 29 in the jsp file:
>> MapGuideJavaApi cannot be resolved
>> config
>> 27:     // file should be in the same folder as this script.
>> 28:     String configPath =  realpath + "webconfig.ini";
>> 29:     MapGuideJavaApi.MgInitializeWebTier( configPath );
>> 30: }
>> 31:
>> 32: String GetQueryXmlTemplatePath()
>> An error occurred at line: 52 in the jsp file:
>> MgLayer cannot be resolved to a type
>> 49:
>> 50: // Searches the map for a layer with the specified name.
>> 51:
>> 52: MgLayer GetLayerByName(MgMap map, String layerName) throws
>> MgException
>> 53: {
>> 54:     MgLayer layer = null;
>> 55:     for (int i = 0; i < map.GetLayers().GetCount(); i++)
>> MgMap cannot be resolved to a type
>> 49:
>> 51:
>> MgException
>> 53: {
>> 49:
>> 51:
>> MgException
>> 53: {
>> An error occurred at line: 54 in the jsp file:
>> 51:
>> MgException
>> 53: {
>> 56:     {
>> 57:         MgLayer nextLayer = (MgLayer) map.GetLayers().GetItem(i);
>> An error occurred at line: 57 in the jsp file:
>> 56:     {
>> 58:         if (nextLayer.GetName().equals(layerName))
>> 59:         {
>> 60:             layer = nextLayer;
>> 56:     {
>> 59:         {
>> An error occurred at line: 67 in the jsp file:
>> MgByteReader cannot be resolved to a type
>> 64:     return layer;
>> 65: }
>> 66:
>> 67: void OutputReaderContent(ServletResponse response, MgByteReader
>> byteReader) throws MgException, Exception
>> 68: {
>> 69:     ByteArrayOutputStream bos = new ByteArrayOutputStream();
>> 70:
>> 64:     return layer;
>> 65: }
>> 66:
>> 68: {
>> 70:
>> An error occurred at line: 33 in the jsp file:
>> MgUserInformation cannot be resolved to a type
>> 30:
>> 31:     InitializeWebTier();
>> 32:
>> 33:     MgUserInformation userInfo = new MgUserInformation("Anonymous",
>> 34:     MgSite site = new MgSite();
>> 35:
>> 36:     site.Open(userInfo);
>> 30:
>> 32:
>> 35:
>> An error occurred at line: 34 in the jsp file:
>> MgSite cannot be resolved to a type
>> 32:
>> 35:
>> 37:
>> 32:
>> 35:
>> 37:
>> Stacktrace:
>> org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:92)
>> org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:330)
>> org.apache.jasper.compiler.JDTCompiler.generateClass(JDTCompiler.java:423)
>> 	org.apache.jasper.compiler.Compiler.compile(Compiler.java:308)
>> 	org.apache.jasper.compiler.Compiler.compile(Compiler.java:286)
>> 	org.apache.jasper.compiler.Compiler.compile(Compiler.java:273)
>> org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:566)
>> org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:317)
>> 	org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:320)
>> 	org.apache.jasper.servlet.JspServlet.service(JspServlet.java:266)
>> 	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
>> note The full stack trace of the root cause is available in the Apache
>> Tomcat/6.0.14 logs.
>> Can you help me? Many thanks
View this message in context: http://www.nabble.com/HTTP-Status-500-running-ajaxviewersample.jsp-tp17718856p17777053.html
