[mapguide-users] ecw on mgos-2.0.1
nclayton
nclayton at gmail.com
Wed Jun 11 13:34:52 EDT 2008
One of the things that I learned about ecw files (at least for my situation)
the coordinate system should show 'Local' instead of 'Default'. 'Default'
usually shows up if the path is not correct.
Are you getting any error messages? on screen or in logs?
ary sucaya wrote:
> Something peculiar happen here. Previously i can open my ecw file, but
> after a few minutes i revisited back my page, the raster has gone. Now, i
> can't even get a new connection work.
> ----- Original Message ----
> From: ary sucaya <ary.sucaya at yahoo.com>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Wednesday, June 11, 2008 6:23:30 PM
> Subject: Re: [mapguide-users] ecw on mgos-2.0.1
> Thanks for your reply. That's help me to solve my problem.
> Regards,
> Ary Sucaya
> From: nclayton <nclayton at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Wednesday, June 11, 2008 5:56:30 PM
> When creating your raster data connections, use "/" instead of "\" in your
> paths.
> C:/Program
> Files/MapGuideOpenSource2.0/WebServerExtensions/www/mapcatalogue/data/world.ecw
> instead of
> C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw
> it may also be a problem with the space in "Program Files". You may need
> to
> place your ecw files in a different location that does not have spaces i
> the
> path.
> hope ths helps
> ary sucaya wrote:
>> Hello group,
>> Did someone succesfully open ecw file on mgos 2.0.1? I went through
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation but i couldn't
>> get it work. i turn on rasters debugging and here is the result:
>> ECW: NCScbmOpenFileView(C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw):
>> eErr = 0
>> ECW: FileInfo: SizeXY=4320,2160 Bands=3
>> OriginXY=-180,90 CellIncrementXY=0.0833333,-0.0833333
>> ECW: projection=GEODETIC, datum=WGS84
>> GDAL: GDALOpen(C:\Program
>> succeeds as ECW.
>> GDAL: GDALClose(C:\Program
>> I tried to change the coordinate system into LL84 (LL84) or LL84-WP
>> (LL84-WP) but still unlucky.. Someone know how to solve this?
>> Regards,
>> Ary Sucaya
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17781203.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
View this message in context: http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17783141.html
