[mapguide-users] ecw on mgos-2.0.1
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 11 22:42:01 EDT 2008
Remember EPSG:4019 is like a fallback default EPSG code and most
likely incorrect
z
On Thu, Jun 12, 2008 at 12:08 PM, Rahul <unicorn_admirer at yahoo.com> wrote:
> Hi,
> I think its should work as previously i had the same problem as my ecw
> file was in LL84(EPSG:4326) and my map also in LL84 but EPSG:4019,so in that
> case i unable to view the ecw layers and get the coordinate transformation
> error but once i changed the coordinate system of Map to LL84(EPSG:4326),
> now i can able to see the 34(136/4) ecw files . Althoug as previously
> discussed there are some performance issues etc .
> I also don't know that why there is no MGCoordinateSystem.dll in the
> MapAgent,Either they removed or is it something to do with coordinate
> transformation problem.
> Max !!
> ----- Original Message ----
> From: ary sucaya <ary.sucaya at yahoo.com>
> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> Sent: Thursday, June 12, 2008 1:38:51 AM
> Subject: Re: [mapguide-users] ecw on mgos-2.0.1
> I don't know exactly what happens here. I have postgis table with geometry
> field in EPSG:4326 coordinate system. I can render it from MGOS 2.0.1 with
> LL84 coordinate system. But if i add ecw file which has EPSG:4326 coordinate
> system, it is disappear from my map unless make use of EPSG:4326 coordinate
> system. I know that this cs do not supported by MGOS and I don't have an
> idea in what coordinate system my ecw file should be. I tried some of
> coordinate system from MapGuide Studio but none of them works for my ecw
> file. The same ecw file works in MGOS 1.2 with LL84 cs. Thanks.
> Regards,
> Ary Sucaya
> From: "Kenneth Skovhede, GEOGRAF A/S" <ks at geograf.dk>
> Sent: Wednesday, June 11, 2008 7:52:59 PM
> MGOS does not support re-projection of rasters.
> Your rasters must be in the same projection as the map.
> If they are not, but the coordinate systems are compatible, you can add a
> coordinate system override on the feature source.
> Beware that MapGuide Studio uses the Mentor projection library and MGOS uses
> PROJ.4.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> ary sucaya skrev:
> I think it is a problem of coordinate system. I can preview my layer but i
> can't see it in map. I tried to create a new map and add the ecw layer,
> mapguide studio automatically add EPSG:4326 (WGS 84) for the coordinate
> system which is not in the list. In this case, i can add another layer and
> able to preview the map.
> Sent: Wednesday, June 11, 2008 6:45:44 PM
> Something peculiar happen here. Previously i can open my ecw file, but after
> a few minutes i revisited back my page, the raster has gone. Now, i can't
> even get a new connection work.
> Sent: Wednesday, June 11, 2008 6:23:30 PM
> Thanks for your reply. That's help me to solve my problem.
> Regards,
> Ary Sucaya
> From: nclayton <nclayton at gmail.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Wednesday, June 11, 2008 5:56:30 PM
> When creating your raster data connections, use "/" instead of "\" in your
> paths.
> C:/Program
> Files/MapGuideOpenSource2.0/WebServerExtensions/www/mapcatalogue/data/world.ecw
> instead of
> C:\Program
> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw
> it may also be a problem with the space in "Program Files". You may need to
> place your ecw files in a different location that does not have spaces i the
> path.
> hope ths helps
> ary sucaya wrote:
>> Hello group,
>> Did someone succesfully open ecw file on mgos 2.0.1? I went through
>> http://trac.osgeo.org/fdo/wiki/FdoGdalNotes#Documentation but i couldn't
>> get it work. i turn on rasters debugging and here is the result:
>> ECW: NCScbmOpenFileView(C:\Program
>> Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapcatalogue\data/world.ecw):
>> eErr = 0
>> ECW: FileInfo: SizeXY=4320,2160 Bands=3
>> OriginXY=-180,90 CellIncrementXY=0.0833333,-0.0833333
>> ECW: projection=GEODETIC, datum=WGS84
>> GDAL: GDALOpen(C:\Program
>> succeeds as ECW.
>> GDAL: GDALClose(C:\Program
>> I tried to change the coordinate system into LL84 (LL84) or LL84-WP
>> (LL84-WP) but still unlucky.. Someone know how to solve this?
>> Regards,
>> Ary Sucaya
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/ecw-on-mgos-2.0.1-tp17778662p17781203.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
