Re[mapguide-users] turn all Layers from MapGuide repository
Darrin Maidlow dmaidlow at landorgis.com
Thu Jun 12 10:38:41 EDT 2008
The following code should do what you're looking for.
	Public Shared Function GetAllResources(ByRef resSvc As
MgResourceService, ByVal resId As MgResourceIdentifier, ByVal nDepth As
Integer, ByVal szType As String) As XmlDocument
		Dim retDoc As XmlDocument
		retDoc = ConvertMgReaderXml(resSvc.EnumerateResources(resId,
nDepth, szType))
		Return XmlDocument
	End Function
Set the , resID to "Library://",  depth to -1 I believe for full recursion.
For Type use LayerDefinition
And ConvertMgReaderXML is:
	Public Shared Function ConvertMgReaderXml(ByVal byteReader As
MgByteReader) As XmlDocument
		Dim szXML As String
		Try
			szXML = byteReader.ToString
		Catch ex As Exception
			Throw ex
		End Try
		Dim nByteCount As Integer
		Dim arrByte(szXML.Length) As Byte
		Try
			nByteCount = Encoding.UTF8.GetBytes(szXML, 0,
szXML.Length, arrByte, 0)
			Throw ex
		End Try
		Dim memStream As New MemoryStream(arrByte)
		Dim retDoc As New XmlDocument
		retDoc.PreserveWhitespace = True
		Try
			retDoc.Load(memStream)
			memStream.Close()
			memStream.Dispose()
			Throw ex
		End Try
		memStream.Close()
		memStream.Dispose()
		Return retDoc
	End Function
Hope that helps.
darrin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of adnan.c
Sent: Thursday, June 12, 2008 4:17 AM
To: mapguide-users at lists.osgeo.org
Subject: Re[mapguide-users] turn all Layers from MapGuide repository
Hello All,
Currently working with the API for MapGuide OpenSource 2.0 and have a
requirement for returning all layers from the MapGuide repository.
I am able to return all layer names for a particular map using the below C#
code
            map.Open(resService, mapName);
            MgLayerCollection layers = map.GetLayers();
            ArrayList layerNames = new ArrayList();
            for (int i = 0; i < layers.GetCount(); i++)
                MgLayer layer = (MgLayer)layers.GetItem(i);
                string layerType = layer.GetFeatureGeometryName();
                    layerNames.Add(layer.GetName());
How would I go about returning all Layers in the MapGuide repository as a
large number of layers won't be associated with a map?
Many Thanks,
Adnan
View this message in context:
http://www.nabble.com/Return-all-Layers-from-MapGuide-repository-tp17796701p
17796701.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
