[mapguide-users] Creating Tile Index Config Files
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 12 15:30:31 EDT 2008
Once you create the index file, it gets attached to the featuresource
(at least for Maestro).
If you look at the setup in Maestro, then select the "Generic" tab.
In the list of resources below, click "Show all".
You should now see the "config" file.
Download that, it is an Xml file.
You can now review the Xml file to see what extents each tile is
expected to have.
You can also edit it manually and put it back with Maestro.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> I can't get this to work for the life of me....I've tried it with both
> methods from the wiki - the php script of Jason's, and from Maestro. I
> have no problem getting the data connection made, but with both
> methods, I'm only ever seeing 1 image - rather than the 7 that I have.
> And the scale of that one image is huge. I'm guessing that it's
> ignoring my georeferencing and just sticking all of my images on top
> of each other at some crazy scale. Any thoughts?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Skipped content of type multipart/related
