[mapguide-users] Cannot Establish Connection
    Mark Pendergraft
    markp at Meadgilman.com
    Thu Jun 12 17:47:54 EDT 2008
It has already been logged by someone else.
http://trac.osgeo.org/mapguide/ticket/524
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, June 12, 2008 2:39 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Cannot Establish Connection
If you are pretty sure about the behavior of SetSelectionXml you might
want to log a trac ticket on the OSGeo site with some details.
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mark
Pendergraft
Sent: Thursday, June 12, 2008 2:46 PM
I see your point.  I will follow the whitepaper and see if it helps.
Thanks.
Sent: Thursday, June 12, 2008 1:38 PM
Yeah, but the post is mainly about disabling the dumping behavior of the
Application Pool. If it can soft fail you might not get some of the
grief you are seeing currently until you discover the root of the issue.
Your code and exception handling may not be the problem. If something
fails within FDO it could cause problems with the provider. Often times
those are exposed as unclassified exceptions. If you ever see those in
your MapGuide error.log then something has gone wrong. Not all
exceptions are logged to the error log.
Of course if the problem is with the .NET API then a fatal error on the
application pool isn't going to get trapped in your error handling
either I would think.
Dave
Pendergraft
Sent: Thursday, June 12, 2008 2:19 PM
Hmmmmnnnnn.  There is quite a bit of error handling in my code, and
everything should be wrapped in a try....catch error block.
Neither of those errors show up in my system or application log.
Sent: Thursday, June 12, 2008 1:04 PM
To be frank no. It's more likely something such as a filter or styling
or something in the data that causes the provider some serious grief.
The trick is to figure out which layer is the likely culprit.
Another possibility is that some custom API coding is doing something
incorrect or hitting some yet unidentified bug.
Check the following and see if this can help alleviate some of the
grief:
http://support.microsoft.com/kb/911816
Dave
Pendergraft
Sent: Thursday, June 12, 2008 1:26 PM
I have been pouring through the Application and Error logs, and the one
Error I consistently get is "Please try your operation later as the
resource was busy"
This is a flaw in MGOS 2.0 which ties up the resource after using the
SetSelectionXML command.
Do you think that this error might be tied to the service constantly
stopping?
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of nclayton
Sent: Thursday, June 12, 2008 11:39 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Cannot Establish Connection
I've been dealing with this since MGOS 1.2 and continue to have the
problem
in 2.0.1
In the Application Error log, i'm getting:
Faulting application mgserver.exe, version 2.0.0.2716, faulting module
msvcr80.dll, version 8.0.50727.1433, fault address 0x00008aa0.
AND
Faulting application w3wp.exe, version 6.0.3790.3959, faulting module
kernel32.dll, version 5.2.3790.4062, fault address 0x0000bee7.
Then the System Error log has:
The MapGuide Server v2.0 service terminated unexpectedly. It has done
this
XX time(s).
AND
A process serving application pool 'MGOS' suffered a fatal communication
error wit the World Wide Web Publishing Service. The process id was
'XXXX'.
The data field contains the error number.
That error number is: 8007006d
A lot of the stability issues were corrected in 2.0.1 but I'm getting
more
crashes now than with 2.0...I've had to change my mgos restart script
from
running every 4 hours to every 1 hour and may have to reduce it
further...
Mark Pendergraft wrote:
> Ever since moving to MGOS 2.0 my map keeps crashing and giving users a
> "Cannot Establish Connection" error.  It appears the service is
actually
> stopping on the machine hosting the map, and I have to go in and
restart
> it.  It happens about every other day, and sometimes several times a
> day.
> The server running MGOS is using Windows Server 2000 sp4 and IIS 8.0
> Any ideas on why this is happening?  It's really starting to get
> annoying, and if I can't find a fix then I will have to downgrade to
> 1.2.
> Thanks.
> -Mark P.
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Cannot-Establish-Connection-tp17803969p17806925.ht
ml
