[mapguide-users] How to customize "Select cursor" functions in Mapguide Studio 2009
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jun 13 07:54:58 EDT 2008
So you want to replace the map when a user clicks a point?
In the layout, set the link target to "top" (or optionally the name of
the frame the map is in).
Then create a tooltip+link on the relevant layer, where the link points
to the desired url, eg.: 'http://mapguide.osgeo.org'.
Now the user can ctrl+click the link to open the new page, the target
ensures that the page is opened in the same window.
If you must have it as a tool, you will have to edit some of the viewer
files.
I think you would start out in the file ajaxmappane.templ.
Beware that this is a bit tricky, because the user may click on a spot
with no data.
Also, note that the tools and commands have numbers, and there is not a
1:1 correspondance.
If you don't want other tools avalible, you can get MapGuide to just
generate a PNG.
In html, you can then use a tag like:
<img src="..." onclick="top.location.href='...';" />
You may get away with hijacking the onclick for the map, rather than go
trough with building a custom tool.
Regards, Kenneth Skovhede, GEOGRAF A/S
gimbrogno @smartlab skrev:
> Ah ok, but I want to create a web page that when the click in a point on the
> map it opens a new link page in the central frame  (where is the map)...
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> Inside Studio.
>> At the bottom grid ("New Commands"), click "Add"  -> "Invoke URL".
>>> Thanks...
>>> Another question, where I must to create this new function ? In the
>>> mainframe.jsp or where?
>>> Thanks a lot...
>>>> No, not directly.
>>>> You can create a new function that opens a page, and make it look like
>>>> the "select button" instead.
>>>>> Hi, I have built an example web layout with a map using Mapguide
>>>>> Studio.
>>>>> There is a metod that customize the function of "select button", for
>>>>> example
>>>>> to open a new page?
>>>>> Thanks a lot...
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080613/573292bb/attachment.html
