[mapguide-users] CPP Build failure on Ubuntu 8.04
SD
temporary130 at gmail.com
Mon Jun 16 22:28:39 EDT 2008
Background:
- went through normal install steps at
http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html
- using files from
http://download.osgeo.org/mapguide/releases/2.0.1/mapguide-2.0.1.2716.tar.gz
Everything works until running ./build_oem.sh where this error occurs:
/bin/sh ./libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I..
-g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
-Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
-finline-functions -ffast-math -fno-strict-aliasing -MT
BufferOutputStream.lo -MD -MP -MF .deps/BufferOutputStream.Tpo -c -o
BufferOutputStream.lo BufferOutputStream.cpp
g++ -DHAVE_CONFIG_H -I.. -g0 -O2 -pipe -Wall -Wno-long-long
-Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef
-Wstrict-prototypes -fforce-addr -finline-functions -ffast-math
-fno-strict-aliasing -MT BufferOutputStream.lo -MD -MP -MF
.deps/BufferOutputStream.Tpo -c BufferOutputStream.cpp -fPIC -DPIC -o
.libs/BufferOutputStream.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid
for Ada/C/ObjC but not for C++
BufferOutputStream.cpp: In member function 'virtual size_t
DWFCore::DWFBufferOutputStream::write(const void*, size_t)':
BufferOutputStream.cpp:192: error: expected primary-expression before '?' token
BufferOutputStream.cpp:192: error: expected `:' before ';' token
BufferOutputStream.cpp:192: error: expected primary-expression before ';' token
make[2]: *** [BufferOutputStream.lo] Error 1
make[2]: Leaving directory
`/opt/install/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
make: *** [all] Error 2
DWFCORE 1.0: Error build failed (0).................
I thought maybe the BufferOutputStream.cpp was corrupted, so compared
it with version at
http://svn.osgeo.org/mapguide/trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/BufferOutputStream.cpp
which was identical.
There is a '?' in the file, but it is on line 110, not 192.
Anyone know what I'm doing wrong? :-)
