[mapguide-users] Re: CPP Build failure on Ubuntu 8.04
Zac Spitzer
zac.spitzer at gmail.com
Tue Jun 17 00:10:39 EDT 2008
Using subversion rather the tar ball is a lot easier
z
On Tue, Jun 17, 2008 at 1:56 PM, SD <temporary130 at gmail.com> wrote:
> On 6/16/08, SD <temporary130 at gmail.com> wrote:
>> Background:
>> - went through normal install steps at
>> http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html
>> - using files from
>> http://download.osgeo.org/mapguide/releases/2.0.1/mapguide-2.0.1.2716.tar.gz
>> Everything works until running ./build_oem.sh where this error occurs:
>> /bin/sh ./libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I..
>> -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
>> -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
>> -finline-functions -ffast-math -fno-strict-aliasing -MT
>> BufferOutputStream.lo -MD -MP -MF .deps/BufferOutputStream.Tpo -c -o
>> BufferOutputStream.lo BufferOutputStream.cpp
>> g++ -DHAVE_CONFIG_H -I.. -g0 -O2 -pipe -Wall -Wno-long-long
>> -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef
>> -Wstrict-prototypes -fforce-addr -finline-functions -ffast-math
>> -fno-strict-aliasing -MT BufferOutputStream.lo -MD -MP -MF
>> .deps/BufferOutputStream.Tpo -c BufferOutputStream.cpp -fPIC -DPIC -o
>> .libs/BufferOutputStream.o
>> cc1plus: warning: command line option "-Wstrict-prototypes" is valid
>> for Ada/C/ObjC but not for C++
>> BufferOutputStream.cpp: In member function 'virtual size_t
>> DWFCore::DWFBufferOutputStream::write(const void*, size_t)':
>> BufferOutputStream.cpp:192: error: expected primary-expression before '?'
>> token
>> BufferOutputStream.cpp:192: error: expected `:' before ';' token
>> BufferOutputStream.cpp:192: error: expected primary-expression before ';'
>> token
>> make[2]: *** [BufferOutputStream.lo] Error 1
>> make[2]: Leaving directory
>> `/opt/install/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> make: *** [all] Error 2
>> DWFCORE 1.0: Error build failed (0).................
>> I thought maybe the BufferOutputStream.cpp was corrupted, so compared
>> it with version at
>> http://svn.osgeo.org/mapguide/trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/BufferOutputStream.cpp
>> which was identical.
>> There is a '?' in the file, but it is on line 110, not 192.
>> Anyone know what I'm doing wrong? :-)
> Ok, I see the problem.
> The downlaod .tar.gz file at
> has an invalid ansi/Core.h
> The correct version can be found at
> http://svn.osgeo.org/mapguide/trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/ansi/Core.h
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
