[mapguide-users] MapGuide for an AVL app?
Vishaal
vs2k2000 at rediffmail.com
Tue Jun 17 05:43:39 EDT 2008
Hi Andy,
i am also trying to make a similar kind of a solution using MGOS1.2 and
Visual Studio2005. i am successful in displaying the points on a button
click all at once. what i want is that on the button click(as you told) my
points should get displayed one by one or one after the other as per the
data and only the latest point should be visible. i am not able to this
part. can you help me with some code example?
thanks.
Andy Morsell wrote:
> Yes, it would work well. As part of your system, you will be feeding a
> database with point information (historic and current) about vehicle
> locations. You would define some queries in that database to extract only
> the latest time-based position. Then, in MGOS, you would point your layer
> definition(s) to these queries where the symbols would be drawn directly
> from the x,y data in the database using the FDO ODBC data provider. A
> little programming using the MGOS API would be necessary to refresh the
> layers at the desired time interval, be it every 10 seconds or every 5
> minutes or whatever. If the latest point data has changed since the last
> refresh, then the vehicle symbols will shift accordingly. Or, you might
> be
> able to write a trigger that would call a stored procedure if new point
> data
> is added and then force a refresh from the server-side.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> _____
> From: Max Brown [mailto:maxbrown3 at gmail.com]
> Sent: Wednesday, April 19, 2006 10:10 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] MapGuide for an AVL app?
> Hello,
> I'm currently evaluating web based mapping software for an AVL system.
> Could
> somebody let me know if Mapguide OS is a suitable dev platform to develop
> a
> web based Vehicle tracking system. Is it possible to dynamically plot
> coordinates on the MapGuide OS platoform.
> Thx
View this message in context: http://www.nabble.com/MapGuide-for-an-AVL-app--tp4001276p17881473.html
