[mapguide-users] Anybody try GPX on OGR
Scott Hameister
scotth at mpower-tech.com
Wed Jun 25 14:24:53 EDT 2008
FRank,
Does 3.3 FDO version Contain the OGR the capabilities for GPX now...I gave
it a try and No luck..Thought maybe i was just missing something...maybe
not.
Frank Warmerdam-2 wrote:
> Scott Hameister wrote:
>> Has anybody out there tried a GPX file from a Garmin or other GPS unit
>> with the OGR provider….
>> ….I don’t know if it works or if I have the Wrong OGR provider for MG1.2
>> RC2…What is the Correct Version and Provider XML string to paste in the
>> XML file?
>> If you have it working did you browse to the GPX in Author or is there
>> some connection string I’m missing?
> Scott,
> I believe the OGR GPX driver is new in OGR 1.5.0 and MapGuide is still
> using GDAL/OGR 1.4.4. It likely wouldn't be terribly hard to backport
> the driver to 1.4.x if you are in a position to build things from source.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Anybody-try-GPX-on-OGR-tp15174738p18116613.html
