[mapguide-users] Silverlight/Moonlight Viewer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 26 05:29:38 EDT 2008
Yes, the http roundtrip time is a beast.
I think the server is (partly) divided, with one part being a repository
manager.
You can already retrieve resources with calls, and coordinate data with
another.
The MgApi interacts directly with the server, it is still serialized,
but binary.
The MgApi uses the loopback connection, but does not use a webserver,
and has no http headers.
So you can still do it, but I agree that it would make sense to divide
the different parts more rigidly.
Regards, Kenneth Skovhede, GEOGRAF A/S
Maksim Sestic skrev:
> Hi Kenneth,
> I guess that someone :-) needs to build a tier-neutral repository
> viewer first, then leverage it's API via Silverlight/Moonlight.
> Presumably using .NET. Currently, the engine is called MapGuide Server
> :-) but it's kernel is server-tier oriented and any external
> communication with it goes via Http on mandatory base. It would be
> perfect if we had respository manager as a separate API - representing
> the actual core. Then, a web-tier API (another component) leverages
> repository API to talk over Http with thin clients. So developers
> might pick if they want to use either web-tier approach (i.e.
> JavaScript) or want to talk via SOAP/linking to the repository manager
> directly.
> Don't know actually... just a couple of thoughts from my side.
> Regards,
> Maksim Sestic
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Thursday, June 26, 2008 10:04
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Silverlight/Moonlight Viewer
> Silverlight uses GDI+, which also supports hardware acceleration.
> I would prefer Silverlight over Java because it intergrates better
> with the html DOM (IMO).
> As for codebase, the current viewers are based on Javascript, and they
> are limited to
> manipulating pre-rendered images.
> The DWF viewer is some of it, but it is still ActiveX based.
> I suppose one could make plugins for all browsers, but it still difficult
> to persuade regular web users to install it.
> Since Silverlight/Moonlight is more likely to be installed already,
> and backed by Microsoft, it will probably be easier.
> Flash is another option, but it is terribly hard to work with (IMO).
> Carl Jokl skrev:
>> I think that there could potentially be a number of alternatives to using an
>> Active X based viewer. I could see potential also for both Flash or Java to
>> create a viewer too. One problem with the Active X viewer in relation to the
>> clients of the company I work for is the security / administrative problem
>> for our clients. Organisations internet security policies could interfere
>> with deployment of an Active X control. I would think though that the same
>> issue would apply to a Java based viewer too. Silverlight might work better
>> in this regard.
>> One of the reasons I find the Java option interesting is the availability of
>> JOGL essentially allowing a Applet or Web Start application to be able to
>> take advantage of Hardware accelerated graphics. I don't know if any
>> alternative viewers have been worked on. If much of MapGuide is open source
>> would that include the viewer? If so it might be possible to start from the
>> existing viewer source code and port it to another platform.
>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>> Has anyone started or is considering starting development of a viewer in
>>> Silverlight/Moonlight?
>>> Such a viewer should be able to achieve performance that is comparable
>>> to the MapGuide 6.5 viewer,
>>> without the need for an ActiveX plugin.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> __________ NOD32 3219 (20080625) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080626/bac63ca3/attachment.html
