[mapguide-users] Silverlight/Moonlight Viewer
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Jun 26 06:07:08 EDT 2008
There are. If you create a MgResourceService object, you are talking to
the repository.
And MaestroAPI uses this (with a LocalNativeConnection) to talk to the
MapGuide server.
I have not followed it all the way, but I think that the
MgResourceService is about as close
as it gets, to the repository content.
Alternatively, you can use DBXml and read the database directly, but
that is a recipie for trouble.
Regards, Kenneth Skovhede, GEOGRAF A/S
Maksim Sestic skrev:
> I agree, the thing is that there's no MG managed wrappers we can
> leverage to talk to the repository manager directly. If we had one, we
> could start from that point on. Could we use Meastro API for
> repository objects serialization/deserialization in managed fashion then?
> Regards,
> Maksim Sestic
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Thursday, June 26, 2008 11:30
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Silverlight/Moonlight Viewer
> Yes, the http roundtrip time is a beast.
> I think the server is (partly) divided, with one part being a
> repository manager.
> You can already retrieve resources with calls, and coordinate data
> with another.
> The MgApi interacts directly with the server, it is still serialized,
> but binary.
> The MgApi uses the loopback connection, but does not use a webserver,
> and has no http headers.
> So you can still do it, but I agree that it would make sense to divide
> the different parts more rigidly.
>> Hi Kenneth,
>> I guess that someone :-) needs to build a tier-neutral repository
>> viewer first, then leverage it's API via Silverlight/Moonlight.
>> Presumably using .NET. Currently, the engine is called MapGuide
>> Server :-) but it's kernel is server-tier oriented and any external
>> communication with it goes via Http on mandatory base. It would be
>> perfect if we had respository manager as a separate API -
>> representing the actual core. Then, a web-tier API (another
>> component) leverages repository API to talk over Http with thin
>> clients. So developers might pick if they want to use either web-tier
>> approach (i.e. JavaScript) or want to talk via SOAP/linking to the
>> Don't know actually... just a couple of thoughts from my side.
>> Regards,
>> Maksim Sestic
>> *Kenneth Skovhede, GEOGRAF A/S
>> *Sent:* Thursday, June 26, 2008 10:04
>> Silverlight uses GDI+, which also supports hardware acceleration.
>> I would prefer Silverlight over Java because it intergrates better
>> with the html DOM (IMO).
>> As for codebase, the current viewers are based on Javascript, and
>> they are limited to
>> manipulating pre-rendered images.
>> The DWF viewer is some of it, but it is still ActiveX based.
>> I suppose one could make plugins for all browsers, but it still
>> difficult
>> to persuade regular web users to install it.
>> Since Silverlight/Moonlight is more likely to be installed already,
>> and backed by Microsoft, it will probably be easier.
>> Flash is another option, but it is terribly hard to work with (IMO).
>> Carl Jokl skrev:
>>> I think that there could potentially be a number of alternatives to using an
>>> Active X based viewer. I could see potential also for both Flash or Java to
>>> create a viewer too. One problem with the Active X viewer in relation to the
>>> clients of the company I work for is the security / administrative problem
>>> for our clients. Organisations internet security policies could interfere
>>> with deployment of an Active X control. I would think though that the same
>>> issue would apply to a Java based viewer too. Silverlight might work better
>>> in this regard.
>>> One of the reasons I find the Java option interesting is the availability of
>>> JOGL essentially allowing a Applet or Web Start application to be able to
>>> take advantage of Hardware accelerated graphics. I don't know if any
>>> alternative viewers have been worked on. If much of MapGuide is open source
>>> would that include the viewer? If so it might be possible to start from the
>>> existing viewer source code and port it to another platform.
>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>> Has anyone started or is considering starting development of a viewer in
>>>> Silverlight/Moonlight?
>>>> Such a viewer should be able to achieve performance that is comparable
>>>> to the MapGuide 6.5 viewer,
>>>> without the need for an ActiveX plugin.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> __________ NOD32 3219 (20080625) Information __________
>> This message was checked by NOD32 antivirus system.
>> http://www.eset.com
> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080626/3b67b329/attachment.html
