[mapguide-users] Programatically create MGP Packages or
dynamically load shape files
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jun 26 08:25:05 EDT 2008
Packages are zip files, meant to just let you move around your
projects....you certainly don't have to have a package made to be able
to display a map. As for your shp file question, depending on your
upload location, you could try making an unmanaged layer pointing to the
upload folder. Your first order of business is likely to download
Maestro - http://trac.osgeo.org/mapguide/wiki/maestro
Andrew
littlecharva wrote:
> Hi,
> I'm starting to get my head around the way MapGuide works, and it seems that
> any maps I want to display have to live in a loaded Package - is that
> correct?
> I want to enable my application to accept Shapefiles uploaded by its users
> and display them. I can't find any information on loading Shapefiles
> directly into the MapGuide API, so is there a way to dynamically create
> Packages and load the Shapefiles into them?
> I'm not after a solution, just a point in the right direction.
> Cheers,
> Anthony
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
