[mapguide-users] Fusion Error When Selecting From Search Results
Shamrock Shooter
dan.allen at mrbgroup.com
Fri Jun 27 15:05:37 EDT 2008
I am running MOS 2.0.1 with AutoDesk Studio 2009. I created a search button
to lookup address from my tax parcels shapefile attribute data. If i run it
in the basic layout it works fine. If I run it in the fusion layout, it
will populate a list of values in the task pane, but when I select one of
the search results, it does not zoom to it in the map and throws me this
error:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
SyntaxError: syntax error
xx)
Can anyone help me out? I tried some searching but didn't find any similar
posts.
View this message in context: http://www.nabble.com/Fusion-Error-When-Selecting-From-Search-Results-tp18161869p18161869.html
