[mapguide-users] How to load SHP file into map guide open source
Jackie Ng
jackie.ng at aecsystems.com.au
Thu Mar 6 02:51:20 EST 2008
If you want to load SHP files into MapGuide you have the following options:
- Use webstudio, which comes bundled w/ the MapGuide Open Source
installation (http://yourservername/mapguide/webstudio/index.html)
- Purchase/Get a trial of Autodesk MapGuide Studio
(http://www.autodesk.com/mapguidestudio)
- Use MapStudio Open Source (http://code.google.com/p/mapstudioos)
If you want to load/create MGP files, use the site administrator
(http://yourservername/mapguide/mapadmin/login.php)
Hope that helps.
- Jackie
Viva_Rose wrote:
> Hello,
> I'm new in Map Guide Open Source. I completed can run the
> dotnetviewersample successful but then how do i load a new map into map
> guide open source. I just have SHP file format. How do i convert the SHP
> file into MGP file..
> Really need help,
> Rose
View this message in context: http://www.nabble.com/How-to-load-SHP-file-into-map-guide-open-source-tp15867619s16610p15868187.html
