Re[mapguide-users] gistering new fusion templates
Jackie Ng jackie.ng at aecsystems.com.au
Fri Mar 7 01:38:23 EST 2008
Hmm ok so now it actually does work like before. That's strange (?)
- Jackie
Paul Spencer-5 wrote:
> Hi Jackie,
> I just tried this and it worked.  I copied the slate template folder
> and called it slate2, then copied the slate.xml file and renamed it
> slate2.xml and a second copy of slate appeared in studio.
> Cheers
> Paul
> On 6-Mar-08, at 2:55 AM, Jackie Ng wrote:
>> Hi All,
>> I remember from the early betas of MGOS 2.0.0 that all I needed to
>> do was
>> copy/rename one of the existing template folders, copy/rename the
>> corresponding xml file, change the path references in that xml file,
>> and it
>> would then get picked up as a new template when invoking
>> EnumerateApplicationTemplates via the mapagent interface.
>> That doesn't seem to work in the final release. So how do you
>> "register" a
>> new fusion template?
>> - Jackie
>> View this message in context:
>> http://www.nabble.com/Registering-new-fusion-templates-tp15868197s16610p15868197.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Paul Spencer
> CTO, DM Solutions Group Inc
> http://www.dmsolutions.ca/
View this message in context: http://www.nabble.com/Registering-new-fusion-templates-tp15868197s16610p15890672.html
