[mapguide-users] Info: phpgenerictask theme -> xml error
web
web at infogeo.ch
Mon Mar 10 07:26:51 EDT 2008
Hi all,
For those who use the theme function of phpgenerictasks:
Sometimes when creating a Theme, an exception occurs in:
classes/theme.php method ApplyTheme():
At this line:
$resourceService->SetResource($layerResId, $byteSource->GetReader(), null);
The error sounds like this:
Error: XML Indexer: Parse error in document at line, 34, char 12. Parser message: Not enough elements to match content model : '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
So after browsing a little the web, I've seen a Post which fixes similar problems for pointrules..
What needs to be done is:
Adding a <SizeContext>DeviceUnits</SizeContext> tag in phpgenerictasks\theme\templates\arearuletemplate.xml
Initially the file is like this:
<AreaRule>
<LegendLabel>%s</LegendLabel>
<Filter>%s</Filter>
<AreaSymbolization2D>
<Fill>
<FillPattern>Solid</FillPattern>
<ForegroundColor>%s</ForegroundColor>
<BackgroundColor>FF000000</BackgroundColor>
</Fill>
<Stroke>
<LineStyle>Solid</LineStyle>
<Thickness>0</Thickness>
<Color>%s</Color>
<Unit>Inches</Unit>
</Stroke>
</AreaSymbolization2D>
</AreaRule>
and it might be changed like this:
<AreaRule>
<Filter>%s</Filter>
<Fill>
</Fill>
<Stroke>
<Color>%s</Color>
<Unit>Inches</Unit>
</Stroke>
</AreaRule>
It solves my problem, hope this can help someone :-)
Cheers, Rémy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080310/968597ad/attachment.html
