[mapguide-users] Dynamic Load WebLayout
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu Mar 13 09:22:25 EDT 2008
Are you sure that your SessionID is valid, and not expired?
Are you sure that you get a Permission Denied error, and not an "Invalid
Content" error?
I know that there are some problems with the BOM on UTF-8 data, other
than that, it looks OK to me.
Regards, Kenneth, GEOGRAF A/S
JotaroKujo skrev:
> Hi,
> I've tried to load dynamically a weblayout, but I get a Permission denied to
> resource error then I try to set the resource on the resource service.
> Here my code:
> String layoutDef = "Session:" + mgSessionId +
> @"//test."+MgResourceType.WebLayout;
> MgResourceIdentifier layoutDefId = new
> MgResourceIdentifier(layoutDef);
> string strLayout = "";
> using (StreamReader rdr = File.OpenText(Server.MapPath(strXmlDir) +
> "Stradario_WebLayout.xml"))
> strLayout = rdr.ReadToEnd();
> System.Text.UTF8Encoding encoding = new System.Text.UTF8Encoding();
> byte[] res = encoding.GetBytes(strLayout);
> MgByteSource src = new MgByteSource(res, res.Length);
> src.MimeType = MgMimeType.Xml;
> MgByteReader layoutDefContent = src.GetReader();
> resourceService.SetResource(layoutDefId, layoutDefContent, null);
> Any hint?
> thnx.
> V.
