[mapguide-users] Problem with the MG 2.0 on IIS 5.0 ...
Shail_GIS
shail_79 at hotmail.com
Fri Mar 14 01:20:34 EDT 2008
Thanks for the quick response.
"mapguide" virtual directory do exist ,
This is the screenshot of it.
http://www.nabble.com/file/p16044599/mapguide%2BIIS.JPG mapguide+IIS.JPG
The .php extension is loaded in the default installation under the path ..
"C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\Php\php5isapi.dll"
There has been two extensions loaded in the default installation.
.php and .fcgi ....
Any clue, what am i doing wrong ....
Thanks,
Jackie Ng wrote:
> Check the following.
> 1 - Does your "mapguide" virtual directory exist?
> 2 - If so, is the .php script extension mapped to
> [YOUR_MAPGUIDE_INSTALL_PATH]\WebServerExtensions\Php\php5isapi.dll ?
> - Jackie
> Shail_GIS wrote:
>> I am a newbie to the Map Gguide. I have been trying to install /
>> uninstall many times MG 2.0 on Windows XP, SP2 with IIS 5.0 all day long
>> I have used following installer,
>> MgServerSetup-2.0.0.exe and MgWebServerExtensionsSetup-2.0.0.exe .
>> I chose .NET as a development mode instead of PHP.
>> But everytime i tries to access the login page on the URL
>> (http://localhost/mapguide/mapadmin/login.php), the message on the
>> browser says ,
>> The specified module could not be found.
>> Did anyone come across this issue?
>> Thanks,
>> Shail
View this message in context: http://www.nabble.com/Problem-with-the-MG-2.0-on-IIS-5.0-...-tp16044380s16610p16044599.html
