[mapguide-users] DB XML Component Error in Dynamic Theming
Rahul
unicorn_admirer at yahoo.com
Tue Mar 18 05:51:26 EDT 2008
Hi All,
I have some sdf files as Polygons and when i want to use the Dynamic Theming(GT Example), its use to give mgdbxmlexception error, although I can do dynamic theming on some other sdf layers in the map but on some layers i am getting exception with pid terminated with exit status'0' .Can anybody give some idea reagarding the same in order to proceed further .
Thks
Max !!
ERROR IN THE MAPGUIDE SERVER
<2008-03-18T14:43:57> Officer Error: An exception occurred in DB XML component.
Error: XML Indexer: Parse error in document at line, 61, char 12. Parser message:
Not enough elements to match content model '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
StackTrace:
- MgResourceServiceHandler.ProcessOperation line 80 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpSetResource.Execute line 109 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\OpSetResource.cpp
- MgServerResourceService.SetResource line 728 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgRepositoryManager.SetResource line 867 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource line 840 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgResourceContentManager.AddResource line 183 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument line 624 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceDefinitionManager.PutDocument line 554 file c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp An exception occurred in DB XML component.
Error: XML Indexer: Parse error in document at line, 61, char 12. Parser message: Not enough elements to match content model : '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
ERROR in the WebServer-
[Tue Mar 18 14:43:20 2008] [warn] FastCGI: (dynamic) server "D:/Program Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe" (pid 4088) terminated with exit with status '0'
[Tue Mar 18 14:43:37 2008] [error] [client 10.0.y.y] FastCGI: server "D:/Program Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe" stderr: PHP Fatal error: Uncaught exception 'mgdbxmlexception' in Unknown on line 0, referer: http://10.0.x.x:8008/mapguide/Officers/theme/thememain.php
[Tue Mar 18 14:43:57 2008] [error] [client 10.0.z.z] FastCGI: server "D:/Program Files/MapGuideOpenSource/WebServerExtensions/Php/php-cgi.exe" stderr: PHP Fatal error: Uncaught exception 'mgdbxmlexception' in Unknown on line 0, referer: http://10.0.x.x:8008/mapguide/Officers/theme/thememain.php
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080318/1cff7432/attachment.html
