[mapguide-users] Copy or rename of resources
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Mar 18 12:03:07 EDT 2008
There is a call named "EnumerateResources" which will tell you what
resources is referencing the resource.
I haven't seen a function that does it all server side. You will
probably have to do it manually.
If you use .Net, the MapGuideAPI has a function for a "smart" copy or
rename:
http://code.google.com/p/mapstudioos/wiki/HowToUseMapGuideAPI
The functions are called "CopyFolderWithReferences" or
"MoveFolderWithReferences".
The callback arguments are a bit confusing, but optional.
Regards. Kenneth, GEOGRAF A/S
peter56 skrev:
> Hi all,
> is it possible to copy and past a resource (e.g. from prototype to project1)
> an if yes, how to do it?
> What I have to do is to create different projects for different users, based
> on an prototype for layers, maps, symbols, ... .
> When I do it by copy and past with MG Studio or mapagent (using
> CopyResource), then a new resource is created. But it is simply a 1:1 copy
> of the original resource, only with a new name. For example the name of the
> FeatureSource is still the original one. The same problem happens with the
> mapsource in the weblayout an the other components.
> What to do?
> Thank you
> Regards,
> Peter
