[mapguide-users] MapGuide 6.5 co-resident with MGOS 2.0
    Kenneth, GEOGRAF A/S
    ks at geograf.dk
    Tue Mar 18 13:03:31 EDT 2008
Yes, that works fine.
However, either product will overwrite the IIS "mapguide" virtual
directory on install.
My solution is to copy the "mapagent_isapi.isa" file into the "mapguide"
virtual folder created by MGOS.
Then you just have to add the path in the "Allowed Extensions" config of
IIS.
If you use the "mapguide65" virtual folder (which is standard) there
should be no problems.
Regards, Kenneth, GEOGRAF A/S
djonio skrev:
> Howdy,
> I should know this but do not.
> Can/Will the old MapGuide 6.5 reside and run on the same server as MGOS 2.0?
> I only have a vague recollection that it could not but I would like to be
> sure.
> dennis
